Old 10-04-2004, 06:35 PM   #1
fast71
Drive it like U stole it
fast71's Avatar
well I lowered it!!!!
Like the title says ! I did it the wrong way but I like it and I guess thats all that matters. I heated the springs and dropped it 2 1/2 in the front and 3 in the rear . It didnt hurt the ride at all ,I know thats hard to believe but its true. What do ya think?
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
fast71 is offline   Reply With Quote
Old 10-04-2004, 06:37 PM   #2
Joe67
67 is sold
Looks good
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 10-04-2004, 07:03 PM   #3
silvertonguedevil
silvertonguedevil's Avatar
Ha ha! I was just thinking about how good that looks. All you did was heat it up? You say the ride is the same? Have you checked your alignment yet?
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 10-04-2004, 07:12 PM   #4
fast71
fast71's Avatar
YES , I had it aligned right after lowering it. In fact the guy at the shop got pissed at me for doing it.
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
Old 10-04-2004, 07:50 PM   #5
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I think it looks good.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-04-2004, 08:16 PM   #6
silvertonguedevil
And he was able to align it with no problems?
-Greg
1974 C20 Cheyenne
Old 10-04-2004, 08:34 PM   #7
Swbman
Looks Good... :p
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay
Swbman is offline   Reply With Quote
Old 10-04-2004, 08:36 PM   #8
70c10
67-72 Addict!
70c10's Avatar
Looks great!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-04-2004, 08:38 PM   #9
fast71
fast71's Avatar
No problems at all . Most people heat the sping in one place . we heated it on three different coils and all the way around . when we felt the truck start to move we took the heat away and bounced the truckand then let it sit to see where it was . It took a good 40 mins to lower all 4 corners.We started at 1pm and took it to the aligment shop at 3pm.I was back on the road by 4.
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
Old 10-04-2004, 08:46 PM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
good luck with it!
Keith
Convert to disc brakes.
Old 10-04-2004, 08:49 PM   #11
1972C10
1972C10's Avatar
I have never heated front springs Make's More sense to me to remove them and cut a coil .
I heated rear springs once the ride sucked bad Maybe i lowered mine too much? It squished all the coils together But sure did look good
1972C10 is offline   Reply With Quote
Old 10-04-2004, 09:11 PM   #12
BIG ORANGE
BIG ORANGE's Avatar
Brian I cant belive you did that. I've lowered lots of trucks over the years and I've aways cut one round out of the front and used square tubbin with longer U bolts. This gets you a 2" drop for around 20.00 bucks plus the alingnment! But your truck does look good!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 10-04-2004, 09:21 PM   #13
68C15
blood type; Retumbo
68C15's Avatar
more, more, MORE!!!
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 10-04-2004, 10:15 PM   #14
hotrodtroy
hotrodtroy's Avatar
Maybe he should get his own truck and keep his mouth shut. my$.02
Looks good. Keep on truckin'.
'72 C-10 w/
'68 Large Journal 327cu.in.
"It's o.k. to dream about what you want to do, until you start doing what you are meant to do." Line from "The Rookie"
hotrodtroy is offline   Reply With Quote
Old 10-06-2004, 04:27 PM   #15
dubie
dubie's Avatar
I always thought that lowering it by heating the springs would alter the tempering of the coils and make them brittle. I am going to take mine out and cut off a coil in the spring to bring the front end down a couple inches
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 10-06-2004, 05:16 PM   #16
fast71
fast71's Avatar
I had done it once before when i was real young and stupid . I heated the springs on one of my Novas and it didnt work that well. I was told to put stands under the bumper and heat the spring till it dropped onto the stands then let them cool . I did this and after about three hours I removed the stands ,The car hit the floor. I had to buy new springs and I said then and there I would NOT do that agian. Well a friend of mine owns this repair shop and i watched him lower his 71 SS Camaro ,That he just got 20 grand out of, with heating the springs . I asked him to do mine and he said Okay and away we went. Now I'm not lying when i say It did not hurt the ride of the truck at all. Infact I think it helped it. This truck was stiff as a brick when it was normal hieght. Now I fell like I'm driving SS nova thatr stays in the grarage. It has a smooth ,curve hugging ride. I might later on go and put drop springs in the rear and spindles up front but right now I'm having fun !!
OH Hotrodtoy the guy is a F==d lover ,Thats his problem
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
Old 10-06-2004, 06:57 PM   #17
CHEVYE
my gas saver
CHEVYE's Avatar
i`ve seen that truck a couple of times and it`s one of the cleanest rides i`ve seen, looking good.
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
Old 10-06-2004, 07:33 PM   #18
fast71
fast71's Avatar
Thank You Eric!!! By the way its been awhile since you have seen it last. Looks 100% better in side now.
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
Old 10-06-2004, 08:56 PM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
Just wait. Give it a while for the springs to settle. You may be happy with it now, but once the springs collapse your tune will change....
Old 10-06-2004, 11:02 PM   #20
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Look's good .....That is a hella clean truck too BTW..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 10-07-2004, 12:12 AM   #21
pissonNOS
senior member
pissonNOS's Avatar
when i cut my coils i cut 2 full coils out we were of the mindset no guts no glory haha and also had a spare set of coils in the shop but anyways i think i cut too much because when u lift the truck the spring are loose and u can literally move them arouind by hand but hell i got it aligned and it rides awesome, if i was looking for ride quality i woulda bought a cadillac or something
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 10-07-2004, 12:19 AM   #22
1972C10
1972C10's Avatar
Same thing here 1 1/2 off the coils and the flop out of the top alingment dowel when the truck is jacked up by the center.
Old 10-07-2004, 12:28 AM   #23
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
You can use "U" bolts to hold the coil to the lower A arm and when you jack it up the coil wont fall out.
sneakysnake is offline   Reply With Quote
Old 10-07-2004, 12:33 AM   #24
bluec10
bluec10's Avatar
I really like the stance you've come up with. It must have been really hard to keep the sides even as you were heating the springs.
Present:
2015 Tacoma. Yeah, not a GM, but I love it.
1969 GMC 32,000 - fix, drive, relax, fix...
2019 BMW R1250 GSA - Yahoooooooo
1979 Honda GL 1000 - retro touring at its best.
Past:
'05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner.
'94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm.
'79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350.
'76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod.
'68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect.
'59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said.
bluec10 is offline   Reply With Quote
Old 10-07-2004, 12:37 AM   #25
1972C10
1972C10's Avatar
Whats going to line it up with that 1 1/4 dowel at the top of the spring cup?
I think Im going to bolt flatbar across the top of the spring for now. get spindles later.
Thread Tools
Display Modes
