Old 10-04-2004, 06:39 PM   #1
cliffsta
Stepsides RULE
cliffsta's Avatar
alternator questions
OK, my batttery is toast, stick a fork in it. It barely makes 11 volts while driving. Idling at stoplights it falls down around 9 volts. How can i check my alternator to see if it is also going south? I know its getting heavy use because of the terminal battery that is running lights, radio, and windshield wipers.
This leads to my next question. Shortly after starting it, there is this god awful ghostly sounding whail coming from the passenger side of the truck. And after i turn the truck off, there is a fast tick tick tick noise coming from the same area that slowly dies away. I honestly don't know exactly where the alternator is, but since the battery is on the right, im assuming the alternator is over there too. The belt worn maybe? Pully worn? Any ideas are welcome.
Cliff
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 10-04-2004, 06:56 PM   #2
Russell
Professional Grade
Russell's Avatar
Sounds like your alternator is fried to me... Probally took your battery with it
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-04-2004, 06:59 PM   #3
hotrodhomi
hotrodhomi's Avatar
take your volt meter and measure at the back of the alt. It should read 13.5 volts +/-
hotrodhomi is offline   Reply With Quote
Old 10-04-2004, 07:10 PM   #4
cliffsta
Stepsides RULE
cliffsta's Avatar
thanks guys! I'll go check that after supper. if my alternator is bad, can i bring the core into Autozone or who ever and get a replacement for little?
Old 10-04-2004, 07:22 PM   #5
hotrodhomi
hotrodhomi's Avatar
should be ~60 bucks... they can also check it for you. dont install your new alt with a dead battery.. you may get away with it, but you run the chance of burning the alt up. do you have a hydrometer to test the battery cells?
Old 10-04-2004, 08:21 PM   #6
cliffsta
Stepsides RULE
cliffsta's Avatar
nah i don't but the battery is my mom's van died a few months ago and we changed both the van's and the truck's near the same time. AAMOF, the warranty stuff is crammed in the ghetto fied garbage that is holding the battery in, but i think the 3 year warranty is expired
My mom said we will order battery tray, hanger, clamp, etc Monday and hopefully get it end of the week / beggining of next. I checked Autozone, and its like 30-40 bucks for a 63 amp, 40+ for 100 amp, which isn't bad, so ill check the alternator tomorrow after school and go from there.
Old 10-04-2004, 08:51 PM   #7
1972C10
1972C10's Avatar
You might want to check on this alternator if your going to replace yours Not really any higher than the 63 amp these trucks use and its a direct swap 94 amp.
ALTERNATOR for a
1984 PONTIAC TRANS AM
Normal Stock
Not Available
Item Part
No.
Warranty Core
Value Unit
Price Availability
Store Web
DURALAST
94 AMP DL7294 LLT $30.00 $64.99
PREMIUM QUALITY REMAN, SOME NEW COMPONENTS
VALUCRAFT
94 AMP 7294 1 YR $30.00 $54.99
http://www1.autozone.com/servlet/UiB...C%7EALTERNATOR
1972C10 is offline   Reply With Quote
Old 10-04-2004, 11:20 PM   #8
1986Silverado
What I drive
1986Silverado's Avatar
My truck did the same thing and I ended up replacing the alternator and battery because the alt had fried the battery. It would charge fine, then I noticed at lights and stop signs the volt meter would drop to around 9 volts. I paid 49.99 at autozone for my 1year warranty 94 amp alternator. That was minus the core charge because I had it in my hands when I went in the door
1986 Chevy Crew Cab Dually(Choo-Choo Conversion)
2006 Chevy Equinox
1986Silverado is offline   Reply With Quote
Old 10-06-2004, 04:33 PM   #9
cliffsta
Stepsides RULE
cliffsta's Avatar
OK i checked the alternator by first getting voltage from the battery with motor off (12 volts cause it had just been on a couple hours before, as it is so dead it probably wouldn't make any), then i started it up, and checked the volts on the battery again and it was up at 14.6 ish where it should be, so i have ruled the alternator out. Last night i ordered entire battery tray assembly and such, and some other goodies Ill make a new thread about the other goodies tonight.
Thread Tools
Display Modes
