Old 10-08-2004, 10:23 PM   #1
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Do you have a good filter installed,could be dirt,or maybe a needle valve sticking.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-09-2004, 01:59 PM   #2
jhauter
The dirt and needle valve are very possible. It currently has the glass bowl filter setup located just before the carb. I've already installed a new gas tank and the fuel line that runs from the pump to the carb. Still some particles are showing up in the glass bowl after several cleanings. It only happens once in great but would hate to have a engine fire. Maybe replace the glass bowl filter setup with a modern style filter?
jhauter is offline   Reply With Quote
Old 10-09-2004, 09:08 PM   #3
jhauter
Carb Troubles
Any words of advise on a carb problem? I have a 58 Chevy Apache that I have replaced the float and rebuilt the carb (single barrel rochester). Made all adjustments correctly, truck idles and runs great. Once in a about every 30 times starting the truck, it idles very fast and gas will pour from the carb body. Take it apart, check all adjustments (fine), starts right up, runs great. Very unexplained and upredictable. Any advise??
Old 10-10-2004, 12:44 AM   #4
Brainchild
Brainchild's Avatar
yeah thats what I did.I used a clear fram on mine so I cvould see what kind of junk was going in there.
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Thread Tools
Display Modes
