10-10-2004, 09:56 PM | #1 |
What engine is this?
I tried looking at de-coding page, now I'm really confused.
The stamped number is:V05TCYV The casting #:3914678 The date stamp is E 3 8, but I believe the 'Burb was built in April-April 19th,9:15 AM is what is wrote up above the visor. Oh, yeah-the block has a casting clock, but I read that Saginaw was the only plant that used this, but the 'V' says it was made at Flint? Is that right? And are these heads any good? 3911032 Thanks in advance
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
10-10-2004, 10:30 PM | #2 |
Professional Grade
If those casting numbers are right, you have yourself a 327 from a 68 Camaro. The heads are found on 327s from a 68 as well. It has a 70 cc combustion chamber, but thats all that Mortec.com tells me
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
10-10-2004, 11:22 PM | #3 |
I'm gonna have to double check the numbers tomorrow. It has every indication of being the original engine in the '68 'Burb that's donating parts for my Panel.
10-10-2004, 11:39 PM | #4 |
Heres the info from my book:
302,327,350 68 camaro & z28 large journal 2 bolt main 327 68 corvette 300, 350 hp large journal 2 bolt main 327 68-69 pass,chevelle,camaro,nova, truck 350 68-74 pass,chevelle,camaro,nova, truck 350 69-76 truck 350 78-79 passenge malibu,camaro,nova That is a busy casting number.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
10-11-2004, 12:05 AM | #5 |
Pritch, have you made any mods to your motor? If so what are they? It sounds to me that we have the same motor. The only thing done is an HEI.
BTW, where is hoytsville from SLC?
'72 C-10 w/ '68 Large Journal 327cu.in. "It's o.k. to dream about what you want to do, until you start doing what you are meant to do." Line from "The Rookie" |
10-11-2004, 11:18 PM | #6 |
I havn't done anything to it yet, except pull it out and stick it on a stand. I don't know if I'll get to it this winter or not. It is still factory stock.
Hoytsville is on I-80, 4 miles south of Coalville and about 10 miles north of Park City. Just about dead center between SLC and Evanston, Wyoming.
Thread Tools | |
Display Modes | |
