Old 10-11-2004, 04:59 PM   #1
Daves72'GMC
Question Where can I get brake lines?
I can't find them either in the part stores, Where can I get the rubber brake hoses that bolt to the frront brake caliper for my 72' 3/4?
Daves72'GMC is offline   Reply With Quote
Old 10-11-2004, 05:51 PM   #2
Sweet72
Sweet72's Avatar
You may have to order the hoses and any lines you may need, check gmc pauls, mothertruckers, ricks, or any of the vendors on this board. You may also buy them from In-line Tube or The Right Stuff. Lines are offered in OEM steel or stainless. I used the stainless lines from The Right Stuff Detailing on my '72 GMC short fleet, they look really good and I don't expect to ever have to change 'em again.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 10-11-2004, 06:41 PM   #3
pickupman
pickupman's Avatar
Dave, I have those brake hoses in stock if you still need them.
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Thread Tools
Display Modes
