Old 10-12-2004, 05:30 PM   #1
Dick Dale
Excelsior, You Fathead.
Dick Dale's Avatar
Doors
I am thinking of buying doors for my 72. If I find a set with no rust, holes and with glass, what is a good price? My doors probably need more work than a good set of used ones.
Go Navy. The Sea Is Ours.
Budget 350 Build
http://67-72chevytrucks.com/vboard/s...38#post2264638
Dick Dale is offline   Reply With Quote
Old 10-12-2004, 05:35 PM   #2
Custom 68
Custom 68's Avatar
72 doors are hard to find therefore they can get pretty expencive. the 67-71 are all the same with the exception 67 has different wing windows and the trim options on all of them (holes)
I know this doesnt answer your question but I looked for 72 doors and couldnt find them. Finally found one for 60 bucks and thought that was a steal.
Good luck
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 10-12-2004, 05:48 PM   #3
Stroker
I would say $200-$300 on average for a set of straight rust free 72 doors .
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 10-12-2004, 05:59 PM   #4
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
isnt the difference between the doors just how the outside door handle bolts on? i thought the inside was the same, the regulator just has a longer shaft for the inner door panel, which could be changed.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 10-12-2004, 06:20 PM   #5
Yellow Cheyenne
They fit the same, but the 72 doors have a screw right below the vent window that attaches the inside door skin to the outside skin, making the 72 door unique.
Randy
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72)
'56 Chevy short step V-8 (My dad bought it new!!)
'70 Olds 442 convertible
'70 Olds Rallye 350
Yellow Cheyenne is offline   Reply With Quote
Old 10-12-2004, 07:16 PM   #6
68w/sbc406
68w/sbc406's Avatar
thanks
Old 10-12-2004, 08:41 PM   #7
MOTHERTRUCKERS
The 72 has no screw hole threaded nuts attached to the door for the interior panel at the bottom also, it uses push in plastic barbs instead.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 10-12-2004, 08:58 PM   #8
68w/sbc406
68w/sbc406's Avatar
they just keep coming
Thread Tools
Display Modes
