Old 10-13-2004, 09:27 AM   #1
nu2-72
WTB Frame horns
I am needing the frame ends for the front of a 4x4. Seems that the previous owner put the wrong tow hooks on the truck and torched the spring hangers. Then they wallered out the mounting holes for the wrong hooks. Then they pulled something very heavy and tore the core support brackets and the frame. What a mess.
I need from the cross brace forward.
Anyone? 64504
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 10-13-2004, 09:49 AM   #2
JimKshortstep4x4
Smile
I believe that I have one side that is good. I will check and let you know which side it is if it will help you.
Jim
Old 10-13-2004, 03:20 PM   #3
nu2-72
Thank you.
Ed at Mothertruckers had the rivets so I am going to try to replace them the right way. Just need parts.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 10-13-2004, 03:26 PM   #4
Hotrodhenryj
Truck Farmer
Hotrodhenryj's Avatar
I have a pair of frame horns from a 1/2 two wheel drive. They look the same as the 4X4 I have here except where the body/shackel mounts to it. Looks like they might work. I can get pics if you want to compare.
Arizona rust free sheetmetal
Hotrodhenryj is offline   Reply With Quote
Old 10-13-2004, 03:33 PM   #5
meathead95
computer illiterate
meathead95's Avatar
sounds to me like you need a new frame.
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 10-13-2004, 07:37 PM   #6
nu2-72
Numbers match on this one.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 10-13-2004, 08:06 PM   #7
JimKshortstep4x4
Smile
I have both frame horns, the right one has a good mount on it but the left one looks like the torch man got to the bracket also, as only part of it is left.
They are available but if you can find some closer you will be better off as they are fairly heavy.
Jim
Old 10-13-2004, 09:24 PM   #8
nu2-72
Thanks everyone. What I really need are the hangers and support mounts. I just figured that it might be easier to cut the frame off instead of drill the rivets out. I think that I can fix the frame problems.
I have had another member offer some parts and he is a lot closer. Let me look at what he has and I will get back with you.
Thanks again. I really want to get this frame to the shop before winter but need it to be right first.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Thread Tools
Display Modes
