Old 10-20-2004, 10:50 PM   #1
Smokin72on20s
Ebay Junky
Smokin72on20s's Avatar
how do i get levers off the column?
i have a 80 something tilt chevy truck column in my truck. how do i take off the original levers (tilt,signal,shifter arm) off so i can put my new ones on?
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain..
1983 Chevy c10 swb 2wd - possible 350tbi supercharged...
Smokin72on20s is offline   Reply With Quote
Old 10-20-2004, 10:58 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Tilt lever is threaded on...just twist it off, a small wrence on the flat spot may be needed.
Turn signal pops off. Grab it, and pull it straight out....towards the door.
The shifter has a pin going from top to bottom, drive it out, and pull it straight out. A spring will probably jump out and poke you in the eye, so watch for that. To re-install the shifter, i normally place the spring in there, then a hack saw blade, and slide the shifter over the blade. The blade will let the shifter slide up to and over the spring instead of butting up against it and not going any further. you'll also need a new nylon bushing on the shifter...look at the old one when it comes out. Your GM dealer should have a million on there shelf...it'd be a good idea to replace the spring too since you'll already be in there.
Old 10-21-2004, 12:32 AM   #3
krue
Designated A-hole!
krue's Avatar
How about posting some pics of how that column looks in your truck if you don't mind.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 10-21-2004, 05:54 AM   #4
Longhorn Man
yeah, a how you got it to fit, and a how you wired it up.
Old 10-21-2004, 08:47 PM   #5
Smokin72on20s
Ebay Junky
i dont have a camera right now, so this is the only crappy pic i have. i bought it with the column already installed, so i am not sure on the details of it.
Thread Tools
Display Modes
