Old 10-21-2004, 02:42 AM   #1
canadianchevy72
Removing ignition on 72
How do you remove the ingition itself on the 72's dash? Ive got everything else but it off and its starting to annoy me. Thanks.
1972 Chevy C/10
350/200r4
canadianchevy72 is offline   Reply With Quote
Old 10-21-2004, 03:28 AM   #2
dyingdeadman
dyingdeadman's Avatar
there is a little hole on the front of the switch. put the key in and turn it to the right to the acc. position. next push something like a paper clip into the hole you will fell it depress then turn the switch counterclock-wise until it stops, you may have to do this several times until it is freely moving. Then using the key remove the switch through the front of bezel.
72 GMC sierra 3/4 ton 402 bb
68 GMC 3/4 ton
2010 camaro rs: daily driver
dyingdeadman is offline   Reply With Quote
Old 10-21-2004, 07:22 AM   #3
Blue Beard
Blue Beard's Avatar
Use some liquid graphite to help lube the unit (Don't get it on your cloths, will stain)
Don't use WD-40 or oil based lubes, the oil just draws dirt and dust into the locks....then you have all sorts of problems.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 10-21-2004, 04:47 PM   #4
Inthuwind
Straight jacket required
Inthuwind's Avatar
What if you don't have a key???
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 10-21-2004, 05:34 PM   #5
jhow66
jhow66's Avatar
no key
Take out a door lock and take to a locksmith(will be keyed the same if ing. lock has not been changed). Otherwise take a screwdriver and pry off stainless cover on switch. The bezel will now screw off.(I hope) Buy new switch and lock or bust lock of of switch.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 10-21-2004, 05:55 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have a write up on how to attackl this problem in the FAQ board. CLICKEY
Thread Tools
Display Modes
