Magnificent bastard
Lowering Suburban rear
I originally posted this in the Suburban forum, but there doesn't seem to be much traffic over there, so I'll try here.
I was looking at the rear axle and frame of my Sub (77 1/2-ton/454/TH400/12-bolt) and was wondering what method works best for dropping the rear end. The Sub frame has a body mount where I think a c-notch would want to go, but I'm just not sure. Basically, I guess I'm asking if there are methods that *don't* work on a Suburban rear end. So how did you guys do it? Any problems or tips? Thanks
1977 Big Block Burb |
17's too small
how bog of a notch do you want?
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows |
Magnificent bastard
Well, I'm not looking to set it on the ground, and I don't want airbags (at least not now), and I don't want to cut through the bed floor. I still use it to tow so I don't want to lose its towing capabilities, and I imagine I will need some helper-type airsprings for that.
Probably a 3/5 or a 4/6 at the most. How much up-travel does the rear end have when the axle is flipped on a 73-87 Suburban?
1977 Big Block Burb Last edited by Bad Karma; 10-27-2004 at 11:07 AM. |
Thread Tools | |
Display Modes | |
