Old 10-28-2004, 04:59 PM   #1
leastbay
Cheapest way to lower truck?
whats the cheapest way to lower my 85? can i just use 3 inch front coils and a shackle ,hanger kit? anybody have pics of a drop like this?
leastbay is offline   Reply With Quote
Old 10-28-2004, 11:18 PM   #2
TIMSPEED
TIMSPEED's Avatar
Cheapest way would be
3" DJM Coils = $250
2" Summit Springs = $90
5" DJM Flip Kit = $90
2" Summit Shackles = $50
Then, get some summit dropped truck shocks, prolly $40 a pop. If you wanna go the SUPER cheap route, then do:
Summit 3" Springs = $100
DJM 5" Flip Kit = $90
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 10-29-2004, 08:34 AM   #3
88Jimmy4x4
88Jimmy4x4's Avatar
Yup, thats what I did....with shocks it ran about $350 or so delivered. Its the cheapest and the easiest to install IMO....all bolt on and completely reversible. Took about 3hrs to install.
heres a pic of the stance.
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 10-29-2004, 11:01 AM   #4
leastbay
did you have to cut the front frame to get that rollpan on? is it fabricated or cna you but it somewheres?
Old 10-29-2004, 11:01 AM   #5
leastbay
also my truck sits even on the ground if i buy a 3/5 kit will the back be lower than the front?
Old 10-29-2004, 01:47 PM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
Your truck sits level now? maybe your front springs are sagged or heated-up to lower....thats odd.
Front pan and rear are from www.customclassic.com and yes some minor trimming is required.
1991 GMC Jimmy 4x4
Old 10-29-2004, 03:43 PM   #7
loblazer
loblazer's Avatar
Cheapest way, flatten the tires!!
Just kidding. I agree with Timspeed, that is the stuff I used to get my Blazer down 5" front and rear. Only I used Belltech shocks because they make a 6" drop for the rear which gives a bit more travel.
October TOM.
Doug
loblazer is offline   Reply With Quote
Old 10-29-2004, 05:10 PM   #8
cliffsta
Stepsides RULE
cliffsta's Avatar
The CHEAPEST way is to cut the front springs (not exactly safe or comfy to ride but it'll be low), and get an el-cheapo hanger set from Autozone. But the less money you spend, the more ride quality is gonna suffer.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 10-29-2004, 05:50 PM   #9
leastbay
yeah its even right now and i have 255 60's in the front and 275's in the rear maybe i will try cutting them for now and if it sucks i will buy the real thing should i cut it from the top or bottom? how much should i take off?
Old 10-29-2004, 06:45 PM   #10
TIMSPEED
TIMSPEED's Avatar
A friend of mine with a 78 C10 lowered his truck the cheap way...
He cut the front springs a full coil (off the bottom). He had the entire spring in a bucket of icewater and he used a sawzall. He then made some "custom" rear hangers, and removed a leaf. Twas bout a 3/5 drop.
See Them Here
Old 10-29-2004, 06:48 PM   #11
leastbay
ok i think im gonna try it with a cut-off tool im not sure about the back i cant really fabricate anything i know autozone has that section of suspension stuff do they list the applications on the hangers and stuff i remember seeing lowering blocks
Old 10-30-2004, 08:51 AM   #12
corn
I cut the front springs on mine in a chop saw, quick, easy, cheap & UNSAFE!
Why do people keep saying cut springs are unsafe?...corn
corn is offline   Reply With Quote
Old 10-30-2004, 10:37 AM   #13
rage'nrat638
rage'nrat638's Avatar
let the air out of the tires
rage'nrat638 is offline   Reply With Quote
Old 10-31-2004, 04:54 PM   #14
leastbay
this is what i bought my buddy a while back had got a kit for a ranger that i helped put on the stuff was good quality
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old 10-31-2004, 11:11 PM   #15
pissonNOS
senior member
pissonNOS's Avatar
maybe its different on a 69 but i just swapped my halfton springs for springs from a 3/4 ton not sure if the spring tension is different but i notice a really good ride still and i cut 2 coils out of them
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 11-01-2004, 09:13 AM   #16
88Jimmy4x4
88Jimmy4x4's Avatar
Lowering blocks only work if your springs are under the axle from the factory, and those cheap lowering shackles are for like toyotas, thats basically mini-truck items.
1991 GMC Jimmy 4x4
Old 11-01-2004, 05:43 PM   #17
leastbay
does anyone know if the hangers and shackles go in the front of the leafspring or the rear? any tips on changing them? i plan on using an angle grinder to take off the rivets
Old 11-01-2004, 07:57 PM   #18
SCOTI
SCOTI's Avatar
Hangers are for the front of the leaf spring, shackles are for the rear.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-01-2004, 09:19 PM   #19
88Jimmy4x4
88Jimmy4x4's Avatar
You do realize that the shackle flip is much more expensive and time consuming than the doing the axle/spring flip?
1991 GMC Jimmy 4x4
Old 11-01-2004, 10:02 PM   #20
leastbay
well this is what i bought
hopefully it wont be too hard i read somewhere i might have to drop the tanks to do the front of the rear spring
Old 11-02-2004, 10:02 PM   #21
BaggedC10
Under construction!
BaggedC10's Avatar
I hope that "Spring Tech" kit isn't really made by AIM/Chassis Tech because it looks like that.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 11-02-2004, 10:42 PM   #22
leastbay
why do you hope that? my buddy bought a kit from them for his ford ranger and it was excellent quality
Old 11-03-2004, 01:48 AM   #23
BaggedC10
Under construction!
BaggedC10's Avatar
I said I hope it ISN'T actually an AIM/Chassis Tech product. Terrible service and products.
Old 11-03-2004, 02:51 AM   #24
leastbay
well if you compare the hangers the ones i bought are squared off and if you look at aim they are rounded i really dont forsee any problems being the items are so simple if it were spindles i would be a little more hesitant
Old 11-03-2004, 05:14 AM   #25
BaggedC10
Under construction!
BaggedC10's Avatar
That's what this guy thought.
I'm not trying to start an argument but good luck.
Thread Tools
Display Modes
