11-04-2004, 01:58 PM | #1 |
71 Chevy 4x4
Need a mechanic's advice
On my 72 Chevy 3/4 ton 4x4 ,the front drive shaft turns all the time . I can jack up the rear of my truck and put my truck in gear and when the rear starts turning the front driveshaft does the same thing . I can grab the front drive shaft and stop it with my hand and with little tention . I know its not suppose to turn while going down the road , but , i know it does and this is not good . Tell me if i can axcess the rear of the 205 transfere case and shim this sumhow and stop the front driveshaft from turning all the time . I had another truck ,in 1982, do the same thing and i had a mechanic to fix it . Any you guys done this and might help explain how to fix my problem ? I hate to take the round cover off the back of my transfere case if i don't know what to do first . I know i can do it , just never have ! Thanks for any help here guys .
Tenn.man(a.k.a.Danny Cummings) |
11-04-2004, 08:30 PM | #2 |
ttt
11-04-2004, 09:52 PM | #3 |
horsepower junkie
every 205 i know of has a slight amount of drag on the front shaft...i dont think there is anything wrong with it at all...
67 short wide box,350/700r4/3.73posi 71 olds cutlass "S" mom bought new..12.30s@113MPH |
11-04-2004, 10:07 PM | #4 |
If you can stop the driveline while the engine is in gear I would not worry about it. Just turning from everything else moving in the same direction---just keep the u-joints lubed
11-04-2004, 10:10 PM | #5 |
blood type; Retumbo
that is a normal characteristic of the 205. the only way to stop this is to remove the front shaft. but then the flange would still turn. the way it is will not cost any gas mileage so I say just leave it alone. (I have rebuilt 3 of these myself)
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
Thread Tools | |
Display Modes | |
