Old 11-09-2004, 08:06 PM   #1
Get R Done
Unhappy Transfer case 208c2 or 241c??
I need help, don't know much about trasfer case models I have a model 208C2 with ratio 261 or a model 241C with ratio 272??? What is the differancein the two??????? Can anyone help???????
SEMPER FIDELIS
Get R Done is offline   Reply With Quote
Old 11-09-2004, 09:06 PM   #2
clarkjw24
I like cheese
clarkjw24's Avatar
I'm not possitive but I think the 241 has a better ratio with an OD trans. I've never had a 241 but thats what I hear.
Cruiser: 1972 K5, 400/TH350/NP205, D44 and 12Bolt, 35 TSLs.
Trail rig: 86 K5, 350 TBI, SM465/NP205, 5.13s, 14ff locked, h1 beadlocks, 42" TSLs, 64" rears, 56" fronts, D60 locked, 35pline, drive flanges, crossover, hydro assist, OBA.
Tow rig: 2002 F350 PSD CC Dually FX4, chipped, cold air intake, BFGs
clarkjw24 is offline   Reply With Quote
Old 11-09-2004, 09:15 PM   #3
1969 GMC
1969 GMC's Avatar
You should have the 241 in your truck, if it is the '89 Blazer you have up for sale.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 11-10-2004, 03:18 AM   #4
1FaastC10
1FaastC10's Avatar
241C should be a drivers side drop IIRC, where the 208 is a passenger side. i think the passenger drop 241s are listed under a different model number.
1FaastC10 is offline   Reply With Quote
Old 11-10-2004, 07:55 AM   #5
Blazer1970
Blazer1970's Avatar
Passenger drop 241s were used in '89 - '91 Blazers and Suburbans. The 241 is the newer design that replaced the 208 in '88 - '89. Both cases have similar specs. Supposedly the 241 has a better oiling system. Low range is also a bit deeper in the 241 as you have noted.
Blazer1970 is offline   Reply With Quote
Old 11-16-2004, 03:00 PM   #6
gn4u2c
gn4u2c's Avatar
Mental note one is not stronger than the other I have blow both models right to hellll. oil system is not worth talking about as both are fine. 241 is a little deeper but that is no matter with a 700 trans. lo range 1st gear is just silly especially with the 4.56 gear i have. I think I can go 2 mph, If i get a good downhill run. I now have a 208 installed.
gn4u2c is offline   Reply With Quote
Old 11-16-2004, 05:52 PM   #7
1FaastC10
1FaastC10's Avatar
why would you go for a 208 over a 241? the 241 not only offers the lower low range, but also the ability to upgrade to a SYE.
Old 11-16-2004, 10:19 PM   #8
1969 GMC
1969 GMC's Avatar
I think the NP241 has a higher tq input rating as well...but then again if its what you got, its what you got.
1969 GMC K2500
1996 Honda Accord
Thread Tools
Display Modes
