11-10-2004, 08:02 PM | #1 |
rear air bags?
I am wanting to bag the back of my '68. What size bags are y'all using? What did ya'll do for brackets? Its already notched and has 6'' ece drop springs
11-10-2004, 08:32 PM | #2 |
Sorry, not trying to hijack your thread but i was wondering the same thing. Will all bags drop the same amount? Also, how much can i drop the rear without having to notch my frame?
Thanks I like you avatar frogs. |
11-10-2004, 10:53 PM | #3 |
no brackets are needed ... simply drill 3 holes in the frame where the bag bolts and the air line pass thru and bolt the bottom to the trailing arm.
I am using 2400 # bags on the rear. Hope this helps ya ... the rear is very, very easy to do. |
11-10-2004, 10:56 PM | #4 |
17's too small
2400 lb
it mounts in the stock location
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows |
11-10-2004, 10:59 PM | #5 |
Head Peon
AirRide also has a bag (9100) that takes one bolt in the top and one bolt in the bottom and the port is on the side of the top plate...they designed it to be a direct replacement for the coil. It's a 2000 lb. sleeve bag....
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 |
11-10-2004, 11:05 PM | #6 | ||
The amount of drop will vary since it is directly affected by how much air psi you like to run. I run mine around town @ 30psi unloaded & the ride is very good. Once I add weight or tow the trailer, I crank the air psi up to level the truck (usually about 60psi) & it rides the same (actually it rides a little better because of the extra weight). AirRide actually recommends a smaller rear airbag but I wanted to err on the safe side & use the larger bag. I would estimate my drop to be @ least 7" but I also have 1.5" blocks so actual drop from the bags would realistically be 5-6" w/40psi of air. The top of my rearend actually rides about 1/2" - 3/4" inside my c-section to give you an idea of where it sits @ ride height. But, @ this level of drop, your rear end (@ the pumpkin) will hit the bottom of the bed floor. Quote:
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-10-2004 at 11:07 PM. |
11-11-2004, 08:48 AM | #7 |
Thanks guys......I guess I was overthinking it. 2400# bag, drill some holes.
Gotcha. |
11-11-2004, 10:19 AM | #8 |
Thanks Scoti, I gues i should go ahead and put in a c section then since i already have my cab and bed off the frame. Do i need anything besides the bracket and a tool to cut it out? How long would you stimate it takes to cut the section out of the frame? Are their any drawbacks to notching the frame or does it not effect the vehicle in any other way?
11-11-2004, 12:35 PM | #9 |
If the bed is already off the frame..... now's the time to do a c-section. It doesn't take long to actually cut the meatal when using a cut-off wheel or plasma. A sawz-all might take a little longer if the heat from the cut dulls the blade.
TIP: Mark the areas to be cut & drill holes @ every sharp angle. This prevents places for stress cracks to develop later. Center the c-section directly above the axle @ ride height before marking any holes or the section to be cut-out.
11-11-2004, 01:16 PM | #10 | |
11-11-2004, 03:45 PM | #11 | |
11-11-2004, 04:15 PM | #12 | |
Good info here. Thanks! I wonder why their instructions were off???
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
11-11-2004, 04:46 PM | #13 |
Thanks so much for your help scoti. It sounds like waiting until i redo my suspension would be a more appropriate time to notch the frame then. I wish i had the money to do it all right now though.
11-11-2004, 07:04 PM | #14 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-11-2004 at 07:07 PM. |
Thread Tools | |
Display Modes | |
