Old 11-13-2004, 03:47 PM   #1
71-longbed
Its Magically Delicious
71-longbed's Avatar
Power Steering pulley help !!!
my ps pulley has started to wobble ... makes a annoying racket.. how do i go about tightening the pulley .... is the nut on the front of the pulley reverse threaded ??... please help .. i need ideas thanks
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 11-13-2004, 03:51 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Should be standard threads, also the pump shaft should accept an allen wrench to hold the shaft while tightening. Try tightening it up, can hurt. I can't imagine it getting bent without you knowing it
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 11-14-2004, 02:29 AM   #3
71-longbed
71-longbed's Avatar
there's no hole for an allen wrench .. i've been told i need a special tool to remove and tighten the pulley .. does anyone have a picture of what this thing looks like ??
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Old 11-14-2004, 08:31 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If the belt is tight enough, you should be able to put a wrench on the nut and tighten it up.
If it still slips, hold the pulley with your hand and tighten the nut with your other hand.
The newer model pumps had the press on pulley which require the special tool.
Old 11-14-2004, 10:35 AM   #5
boraxman
Keepin an eye out
boraxman's Avatar
I would check the keyway on that pulley. Mine was loose and it messed up the keyway, ended up w/ new pulley and pump.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 11-14-2004, 02:34 PM   #6
71-longbed
71-longbed's Avatar
i think the bearings probaly shot .. i can pop the pulley back and forth about 1/16 inch.. the belts tight and the nut doesn't want to tighten on anymore ... whats the keyway ???
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Old 11-14-2004, 02:36 PM   #7
Tx Firefighter
That 1/16 movement is normal on all of my pumps. Never any leak or problem with them.
The key way is inside the pulley, on the shaft of the pump itself. It's a notch cut out of the shaft that a key fits into. This key keeps the pulley from spining on the shaft.
Old 11-14-2004, 02:46 PM   #8
71-longbed
71-longbed's Avatar
how do you check the keyway then ,, if its on the shaft ?? im confused
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Thread Tools
Display Modes
