Old 11-14-2004, 01:28 PM   #1
bossrod
Power Brake adjustable rod question?
I'm converting to power brakes on my 72' c-10, 2wd and after I installed the booster/bracket, the adjustable rod that goes to the pedal was not long enough. Do they make different length rods for different applications? Please let me know if you can help me solve yet another problem....bossrod
bossrod is offline   Reply With Quote
Old 11-14-2004, 01:47 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Do you have all of the correct linkage and brackets?
Old 11-15-2004, 07:28 AM   #3
bossrod
Linkage
I've got everything that's shown in your pic. The rod that is coming off the bracket pivot and goes thru the firewall is the one that is too short. Is there a different rod or pedal for the power brake setup? Thank's for the reply and let me know what you think...bossrod
Old 11-15-2004, 07:55 AM   #4
Tx Firefighter
No sir, same pedal and everything.
I snapped those pictures as I was converting my truck to power brakes.
Once you bolt the booster assembly to the firewall, you have to slightly depress the brake pedal to get the hole for the pin to line up. That is, your brake pedal will sit slightly closer to the floor than it did with manual brakes.
Old 11-15-2004, 11:08 AM   #5
SCOTI
SCOTI's Avatar
Tx Firefighter No sir, same pedal and everything.
I had the same problem when I swapped to discs on my 68. I used the pwr brake brakets (same as pictured) from a 71 model along w/all the 71's under-dash hardware including that adjustment rod. The rod from both the 71 & my 68 were too short. I wound up splicing the 2 together.
Tx Firefighter .... you have to slightly depress the brake pedal to get the hole for the pin to line up. That is, your brake pedal will sit slightly closer to the floor than it did with manual brakes.
I tried that & the pedal was between 1/3 - 1/2 way to the floor which didn't seem right. I adjusted the rod & jam-nut about 1/3 out on its travel (this allows room to lengthen/shorten if needed, just like factory). I measured the distance between the center of the holes & cut the rod for that length.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Thread Tools
Display Modes
