Need help everyone!
On the weekend I decided to due a minor tune up. I changed the plugs, wires, Distrubutor cap & rotor on my 396 & went to start it back up it ran but very rough & stalled a few times. Then it started spitting gas back throught the carb & a small fire in the carb????
Timing off???? not sure how never moved the distributor??? Any help would be great. Thanks |
Left Foot Functioning
First thing in such a case - carefully check each plug wire to make sure they're in the right sequence and running to the correct cylinder.
I've done it, as have most others. You look at it for 3 hours, can't see it, then your buddy walks up and says "aren't these hooked up wrong"?... SSOW ![]()
69 C10 (#1 son's ride) 72 C20 (Dad's farm truck) 82 K30 (Ex - brush pumper project) |
![]() Join Date: Sep 2002
You have crossed spark plug wires. check every one with the firing order on the intake manifold. if it is original. if not get a tune up book.
Certifiably crazy person |
diagram
anyone know the firing sequence for a 396????
1-8-4-3-6-5-7-2---clockwise
drivers side 1-3-5-7 pass. side 2-4-6-8
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Thanks everyone will try that & see where it takes me!!!
Finish the'71..or bust!
Ditto jhow66.
Here's a pic for reference: |
Thanks for the diagram that is perfect!!! Hopefully I just mixed a wire up!
Thread Tools | |
Display Modes | |
