Old 11-15-2004, 05:17 PM   #1
Bryce M
Best Front end rebuild kit
I have been looking at getting a complete front end rebuild kit I snagged a 76 front end for my truck I have seen most kits are in the mid to high 200s I want either poly or polygraphite bushings where has the best deal
BTW I have EVERYTHING from the 76 i just cut the frame from the cab forward and took it all
Bryce M is offline   Reply With Quote
Old 11-15-2004, 05:28 PM   #2
PRUNEDA
'87
PRUNEDA's Avatar
you can try and check out www.p-s-t.com and have them send you a free catalog.
PRUNEDA is offline   Reply With Quote
Old 11-15-2004, 05:51 PM   #3
arkracing
Weekend Warrior
Summit
You can buy all "MOOG" Chassis parts and Energy Suspension bushings(for the 73+ front end. through Summit Racing (summitracing.com) -
That's how I did mine and it actually came out cheaper than if I bought the kit from Early Classic Enterprises.
What is included in the rebuild kit for $200???? It was close to $475 for all of my stuff..but that was control arm shafts, ball joints, inner and outer tierods, pitman arm, idler arm
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 11-15-2004, 09:55 PM   #4
Bryce M
It comes with all the bushings ball joints tie rods for 220 and for 280 you get the sway bar mounts and idler arm
Old 11-15-2004, 10:33 PM   #5
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
where are you getting this 200$ kit from?
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 11-15-2004, 10:50 PM   #6
arkracing
Weekend Warrior
probably cheap non-warranty chine Stuff though..Moog has lifetime on Chassis parts...I don't know..I'd rather pay more for the peace of mind - especially with Chassis parts. Even Early Classic's kit is like $450-$500 depending on the model
-'66 C10 Suburban
Old 11-16-2004, 06:06 PM   #7
Bryce M
pst has a kit for 220 www.performancesuspension.com has one for 280 shipped both have a lifetime warranty
Rember the 73+ kit Is cheaper the 72 down cost more cash I went to the newer front end because of that and it has discs and the 5 lug pattern i wanted instead of trying to improve something with more expensive parts
Old 11-16-2004, 06:37 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Bryce, if you want polygraphite , I believe PST is your only option. Polyurethane is more common, but it tends to be noisy.
I have used a couple of PST kits before. I don't know what brand their parts are because they come in plastic baggies, rather than boxes like Moog. Only issue I had, was both cars the rubber boots on the balljoints cracked after about a year or so. They looked like they were 100 years old, all split and dry.
Thread Tools
Display Modes
