Old 11-26-2004, 01:18 AM   #1
Gray Ghost
Gray Ghost's Avatar
Block number decoding
I got these codes off the truck block in my C-20 and went to Mortec to decode....they have no numbers that match these and no link to anywhere that does. I would like to find out where this motor came from so I can decide better what to do if the block has issues when I get the thing torn down (like bad rings, etc.). For those who don't know, I had a head gasket go bad on me this week.
Here are the numbers....can anyone decode them? These were found at the front left of the block under the alternator bracket.
16R409392
TO905CMJ
Thanks, Kelly
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 11-26-2004, 01:40 AM   #2
leastbay
what kind of motor is it i know on my 350 the codes are by the firewall on the drivers side
leastbay is offline   Reply With Quote
Old 11-26-2004, 10:25 AM   #3
dons454s
dons454s's Avatar
Could be a 350 or 305 according to my book you will need to get the back number off the block to be sure
dons454s is offline   Reply With Quote
Old 11-26-2004, 12:20 PM   #4
us111
numbers
your gonna need the number's off of back of block like they said..there located on driver's side right at back of block..some are really hard to see,,i have heard of people using like play dough to put down in there and transfer number's,,,also have heard of using tin foil...you get these number's and they will point you where you need to go..good luck
us111 is offline   Reply With Quote
Old 11-26-2004, 01:42 PM   #5
SanitysBane
some times its really heard because off casting flast on the numbers too, its a real pita
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 11-27-2004, 06:25 PM   #6
BIGCHEVYMAN
BIGCHEVYMAN's Avatar
good site
this is a good site to find engine numbers. www.nastyz28.com
BIGCHEVYMAN is offline   Reply With Quote
Old 11-27-2004, 06:45 PM   #7
Gray Ghost
Gray Ghost's Avatar
Thanks...I got it decoded...1974 350 4 bolt (could be police motor block) in a Caprice/Impala body style. I think I'll keep it....
The numbers off the back of the block don't tell ya much....3970014 = 2-4 bolt 350 70-76...not much info there.
Kelly
Thread Tools
Display Modes
