Old 11-27-2004, 02:08 AM   #1
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
oil pan
is there anything to removeing the oil pan other then draining oil, takeing bolts off like puting on/off valve covers? or do I have to remove other things to get it off.. I am thinking about puting a new oil pick up and pan gasket and cleaning the pan out. thank you
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 11-27-2004, 05:28 AM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Depends on the oil pan gasket(s) you use but yeah that's basically all there is to it. Its not real hard its just some of the positions you have to get into. To reinstall the bolts I used a deep well socket stuffed with some paper towel and a long extension. I put just enough paper towel in the socket that the bolt would go into the socket but not much. It helped out a lot on the ones you can't reach to finger tighten them. For the oil pan gasket I used a Felpro (permaseal?) One piece oil pan gasket. Its like 25.00 but you get all new hard ware, four screw in plastic pens that align the oil pan up and the gasket.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 11-27-2004, 09:04 AM   #3
79gmcc15
79gmcc15's Avatar
Very cool. I .looked up that gasket and its Perma-Dry Plus and will set me back a lill under 30. looks like a realy good set! thank you for the tips! Matt
RIP ELJAY
Old 11-27-2004, 10:06 PM   #4
MylilBowTie
Right turn Clyde
Your welcome
Thread Tools
Display Modes
