11-27-2004, 11:08 PM | #1 |
Bleeding front brakes
I got the back ones bled no problem. The front ones are being a pain. I cant get my wrench in there to loosen the valve. The ones on the back were pointing straight but the ones up front are angled. Is there a special wrench I need to get this done? Btw this is a all drum setup.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
11-28-2004, 12:38 AM | #2 |
Ttt
11-28-2004, 12:52 AM | #3 |
do you have the wheel off??
if not it should help you get your head in far enough with a drop light (if you have one) to see what ur doing and get the wrench on there
(Only) Member of the CPNE Fan Club Aint that the truth 67 C-10 350 with 3-speed tranny and 308 gears swb step 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
11-28-2004, 01:04 AM | #4 |
Here is a pic of the bleeder. Its kinda tough to tell but at the angle it is at I cant get a wrench on there at all. I have tried to get a socket in there as well and it would not go in far enough to get a bite on the head. Any suggestions?
11-28-2004, 01:19 AM | #5 |
10/30/19
Can you get a nut driver on it?
11-28-2004, 01:22 AM | #6 | |
Nope. It wont catch the head of it.
11-28-2004, 01:23 AM | #7 |
When I did mine I know I had a few cramps by the time I was done. I blocked mine & pulled the tire off, & it was still awquard as hell. Maybe a thin walled deep socket might help to get it loosend. I can't really remember exactly how I got mine done, perhaps it was such a traumatic experience my mind is blocking it out . But I seem to remember if you get the right end of the wrench at just the right angle you can move the bleeder just enough to get the job done, but it ain't easy. Don't forget to swear lots. Good luck.
11-28-2004, 01:25 AM | #8 |
10/30/19
Both driver and passenger sides are identical?I wonder if changing wheel cylinders will help?
11-28-2004, 01:29 AM | #9 |
Purple Gas I have been swearing enough belive me I have a thin walled socker that I tried and same thing no luck. Just barley misses the head of it.
Looking at the pic again the problem is the piece that I colered in red. What is that piece anyway.
11-28-2004, 01:29 AM | #10 |
10/30/19
Maybe you could pull your brake line and put a longer bleeder screw in.
11-28-2004, 01:30 AM | #11 |
Yep I could. Would do it to both sides to. How much brake fluid would shoot out if I did that?
11-28-2004, 01:35 AM | #12 |
10/30/19
It will probably leak unless you find a way to stop the bleeding so to speak.I always keep lots of brake fluid around.
11-28-2004, 01:58 AM | #13 |
That part in red is just part of the casting for the spindle holder dealy I think. I had one new cylinder & one old one. I think I maybe did put a new bleeder in the old one though. But I had to replace the hose on the side with the old cylinder, maybe that's how I got mine started. It sat for 8 yrs, so some stuff was pretty crusty. If your real ambitious, or need to put new shoes on maybe pull the cylinder through the front to get the bleeder loose, or put a new longer one on. Damn, where are the experts when you need one?
11-28-2004, 02:01 AM | #14 |
10/30/19
The experts are probably sleeping.
11-28-2004, 05:49 AM | #15 |
Have you tried a deep, 1/4" drive socket, with a short(2") extension? Just offering suggestions. Good luck.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
11-28-2004, 07:40 AM | #16 | |
From the pics, it lools like you might have some rust/mud/crud buildup on that red circle area. Use hammer & chisel/screwdriver to gently chip away at what's there to see if you can gain clearance. If you're working with cylinders more than 10 years old, I'd replace them and the hoses. In any case, consider switching to Russell Perf Speed Bleeders. All the 67-72 C/K10/20 trucks use #639590, 3/8–24 (verify yourself!). They take a 3/8" wrench. Is that smaller than what you have to ease getting a wrench on them? I even install Speed Bleeders in brand new calipers and wheel cylinders. One man bleeding. I'm no expert, but I'm awake.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 11-28-2004 at 07:45 AM. |
11-28-2004, 08:23 AM | #17 |
Still drivin' a Rat Rod
I vote for the deepwell socket too.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
11-28-2004, 08:30 AM | #18 | |
Inline 69
11-28-2004, 10:03 AM | #19 |
Watch out for your cornhole !
I use a 1/4 drive deep socket and it works fine.
Cheaper sockets tend to have thicker walls to make up some strength. A situation like this is where Snap-on or Mac quality socket will work that a more inexpensive brand won't.
11-28-2004, 05:06 PM | #20 |
Tried the deepwell and it doesnt get a bite on it. Looks like I am going to have to go for the bleeder replacement.
11-28-2004, 05:11 PM | #21 |
10/30/19
At least it is an inexpensive item.
11-28-2004, 06:39 PM | #22 |
remember: If it don't kill you, it makes you stronger!
11-28-2004, 06:53 PM | #23 | |
Member since 2000
or really hurts you |
11-28-2004, 07:02 PM | #24 |
I had to call it quits for the day guys. Kids are going bonkers and so is the wife I have tomorrow off so guess what I will be doing.
Thread Tools | |
Display Modes | |
