Old 11-28-2004, 09:23 PM   #1
SnS C10
SnS C10's Avatar
fuel sending unit
i tried to hook up my gas gauge awhile ago and when it was hooked up, the needle always went past full. when it was unhooked, it read empty. so i tried a vdo gas gauge, hooked up a power wire and ground wire and the sending unit wire and it still didnt work. so u guys think i just need a new sending unit or is there something else that u guys recommend i do? thanks. i was just thinkin i will buy a new sending unit but would like to hear your suggestions
SnS C10 is offline   Reply With Quote
Old 11-29-2004, 09:07 AM   #2
JimKshortstep4x4
Can you clarify on what happens when the gauge is hooked up or unhooked up?
You said tha when it is hooked up it reads past full but unhooked it read empty. The gauge really should just do the opposite.
Jim
Old 11-29-2004, 09:36 AM   #3
70c10
67-72 Addict!
70c10's Avatar
Jim is correct. I am going thru this as we speak. It sounds like your problem is a broken wire. Run a new wire from the sending unit to the fuse block and see if it fixes it. My problem is the opposite (always on empty unless I unplug it)and I have found a pinhole in the float. I will be replacing it one evening this week and will report back with the results.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-29-2004, 07:46 PM   #4
SnS C10
SnS C10's Avatar
actually i checked it out again and when i unhook the sending unit wire, the gauge reads past full. it does the same on my new vdo gas gauge. so i replaced the wire to see if the wire is bad. it did the exact same thing with a new wire. so im gonna be ordering a new sending unit, thanks guys
Old 11-29-2004, 08:01 PM   #5
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I have successfully taken the sender apart,and cleaned the contacts inside and it work.I did it on the 71 I am now driving.
All I did was bend the little tabs out with a small screwdriver,enough to allow the square box,with the float arm through it to come off,and then clean the inside of the sender with some contact cleaner,and put it back together,and it works great.If it's just dirt could save ya some $$$.I mean ya gotta order one anyway
Be careful not to break the tabs off,they are really small
You can ground the unit,and plug the wire into the sender,and move the float arm to test it.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 11-29-2004, 08:14 PM   #6
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
I did the same thing Branchild did, I just cleaned mine out. It had yellow-green corrosion all inside it so I sprayed some LPS industrial contact cleaner on it, put it back together and it worked like it should.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 11-29-2004, 09:09 PM   #7
Blue Beard
Blue Beard's Avatar
Don't mean to hi-jack a thread but this is along the same lines.
Any help with a dual tank setup.....no matter which tank is switched on only reads 1/4 tank when full...
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Thread Tools
Display Modes
