Old 11-29-2004, 01:29 PM   #1
dubie
dubie's Avatar
Best Valve cover Gaskets
What is the best gasket to buy? I have some cork ones that came with my gasket kit for the engine, but they leak . I have some aftermarket chrome valve covers on the engine, and these gaskets don't seal worth a sh!t. They seem to leak on the outside corners and it has made my nice chevy orange engine look like it has 100,000 + miles on it with the oil runs on it. What gaskets do you recommend?
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 11-29-2004, 01:33 PM   #2
Super Duck
Chevy Nuttttt
Super Duck's Avatar
Speed Way motors sells a rubber gasket with a steal core for I think $15. check them out they have some cool stuff
67' Chev swb step side
69' SS elky
03' Chev ext cab 4X4
hey who lernt me to spell
is there anything else?
Super Duck is offline   Reply With Quote
Old 11-29-2004, 01:34 PM   #3
Mudder
Mudder's Avatar
Well I have red rubber ones from GM on mine and they have been reused a couple of times ans still dont leak. I do have the center bolt valve covers tho and I don't think they leak as bad as the old ones.
Mudder is offline   Reply With Quote
Old 11-29-2004, 01:37 PM   #4
70c10
67-72 Addict!
70c10's Avatar
Tim, I have the fel Pro reusable ones. They are not expensive.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-29-2004, 01:40 PM   #5
junkyardjohn
junkyardjohn's Avatar
I ALWAYS USE THE FEL-PRO BLUE STRIPE RUBBER VALVE COVER GASKETS. I GLUE THEM TO THE VALVE COVERS WITH PERMATEX WEATHER STIP ADHESIVE (OR GORILLA SNOT). NO LEAKS & THEY ARE REUSABLE.
JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 11-29-2004, 02:10 PM   #6
djracer
djracer's Avatar
you may want to check the valve covers if they have been over torqued and bent they may never seal. I use the cork gaskets with the metal inbetween two layers of cork!
Good Luck
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 11-29-2004, 02:11 PM   #7
mindhive
Fel Pro Permadry Plus
Valve Cover P/N VS12869T
Oil Pan P/N OS34510T
Water Neck P/N 35562C
Available from Summit Racing, Jegs, etc
mindhive is offline   Reply With Quote
Old 11-29-2004, 02:37 PM   #8
lngbed71
Nothing fits but the oil
lngbed71's Avatar
Permadry
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
Old 11-29-2004, 03:57 PM   #9
arkracing
Weekend Warrior
Are there any "extra thick" valve cover gaskets out there? who makes them? what are the made of? and where can I get them for a BigBlock?
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 11-29-2004, 10:54 PM   #10
4x4Poet
djracer's recommendation on checking the covers' straightness is a great first step. Given straight valve covers, any inexpensive cork or cork/metal/cork gasket should work well if you use an adhesive, say Edelbrock Gasgacinch, to seal the gasket to the valve cover first, then apply oil or anti-seize to the gasket surface that mates with the head surface. Torque bolts to spec. If the bolts won't retain their torque setting, consider Stage 8's valve cover bolts (8960 for 8 1/4-20 bolts) with "groove locks." The anti-seize will allow removal of the valve cover without scraping off gasket material from the head and the gasket will usually be reusable as still adhered to the cover.
If you still find you need a superior gasket, Summit carries several reusable gaskets that keep their shape and need no adhesive:
Earl' "Pressure Master Valve Cover Seals" for SBC and BBC. Metal sandwiched between shape-retaining rubber. Big bucks!
SCE "Accu-Seal Pro valve cover gaskets" for BBC that are 3/16" thick made from "a two-layer composite of super-strong cellulose and high-density cork. The end result gives you a gasket with superior sealing ability and 1,250 lb. tensile strength for reliability." Sounds like the strength of rubber combined with the good sealing properties fo cork. SCE's SBC gaskets are only 1/8" thick. Medium bucks!
Moroso "Perm-Align valve cover gaskets are manufactured from 30-durometer rubber, which is molded over and vulcanized to a rigid steel frame." Also 3/16" thick for both SBC & BBC. Medium (SBC) & big (BBC) bucks!
Check your local parts store or speed shop.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 11-29-2004, 11:02 PM   #11
Hooter
My other Love
Hooter's Avatar
I always had a problem with the chrome valve covers leaking on my small block, till I switched to aluminum valve covers, my Monte used to have the chrome ones, no matter what they would lea k, so now that I installed the aluminum ones with the blue silicone gaskets I have no more leaks, some of those chrome valve covers are garbage, what I would try is either buy some aluminum valve covers or get some of those wide spreader bars
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 11-30-2004, 12:25 AM   #12
4x4Poet
Good point on the usual chrome valve cover quality, Hooter. It might be because chrome weakens steel, and the producers chrome no thicker steel than the stock steel covers. Also, IIRC, chrome valve covers pass heat with approx 80% less efficiency than painted steel, given the same type of cover (type steel & thickness). Of course, alum releases heat better than both.
Old 11-30-2004, 02:00 AM   #13
longnlow72
longnlow72's Avatar
JOHN
x2
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done...
longnlow72 is offline   Reply With Quote
Thread Tools
Display Modes
