11-29-2004, 03:11 PM | #1 |
Red
Battery or alternator?
This morning (and for the third time this month) I went to start my 72 and NOTHIN' no lights or sound or anything---dead. After last time I recharged the batt and it tested o.k. , today I had the alternator tested and it tested o.k.? Each time the truck had set for 2-3 days withought being driven. Each time after recharging, the truck started easily, and did so the rest of the week---- daily driver. I haven't added anything electrical or changed anything. The guy at NAPA, said that even though the alt. tested good it could be drawing down the battery over those two days. What do ya'll think? I CAN replace both, would prefer to replace just the culprit though. The battery is a Duralast and IS 6 yr. old. I cleaned the posts(which were not bad) this a.m. and still nothin.
Mike
'72 Cheyenne LWB 350/350 "The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game). Last edited by Mike Culpepper; 11-29-2004 at 03:13 PM. |
11-29-2004, 03:30 PM | #2 |
It's a catastrophic success.
With a charged battery, pull the neg. cable off use a test light or bulb (not a meter it will read though the diods). place the bulb(series) between the post and wire if there is a drain the bulb will glow.Be sure to have everything off and doors closed. If it does glow pull the wires on the alt. that will eliminate it.If it doesnt glow then you may have a bad cell in your battery draining it down but a load test will usually detect this.
11-29-2004, 03:36 PM | #3 |
Chevy Nuttttt
the other thing to look at while doing that test is if the light does come on pull one fuse at a time and when it goes out you have found the syst with a draw.(short)
67' Chev swb step side 69' SS elky 03' Chev ext cab 4X4 hey who lernt me to spell is there anything else? |
11-29-2004, 04:07 PM | #4 | |
Red
which wire? Should I check both wires on the alt. one at a time? Since I don't always have a firm grasp on the obvious..... I should use a test light with one end hooked to the neg. battery post and the other touching one of the two wires going into the alternator, and if the alternator is draining the battery, the test light should light, correct? THen check the other wire going into the alternator. Mike
'72 Cheyenne LWB 350/350 "The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game). |
11-29-2004, 04:10 PM | #5 |
Red
Super Duck,
IF the test bulb lights as described abouve, then the draw COULD be any electrical component? And to test this is where I would pull one fuse at a time, Correct? Mike
11-29-2004, 04:16 PM | #6 |
Chevy Nuttttt
corect. if there is a draw on the system you will find it. then have fun finding the prob from there. it will mean shooting wires. if you are lucky it will be a switch for the glove box light or a cig lighter.
11-29-2004, 04:44 PM | #7 |
Red
Thanks to both of ya'll
Mike
11-29-2004, 04:58 PM | #8 |
Chevy Nuttttt
let me know what you find
11-29-2004, 05:15 PM | #9 |
"Ochre Ogre"
If your horn doesn't work start there! The horn relay is stuck on and I'll tell you right now that it just happens to be a 2-3 day battery drain. It happens so often that it has become the first place I look.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
11-29-2004, 05:30 PM | #10 |
Chevy Nuttttt
good call. difrent vehicle types have there own querks
11-29-2004, 07:44 PM | #11 | |
11-29-2004, 09:56 PM | #12 |
its all about the +6 inches
There is a pic of this and detailed instructions in the FAQ section.
11-29-2004, 09:58 PM | #13 |
Personally if I had a battery that was 6 years old and began to give me any kind of problem, I would replace it.
12-13-2004, 11:06 AM | #14 |
Red
Sorry, I didn't see these last couple posts. I will look in the FAQ section, and I did replace the batt. just coz it was so old.
Thanks again Mike
Thread Tools | |
Display Modes | |
