Old 11-30-2004, 12:42 AM   #1
love it loud
Calibration Engineer
love it loud's Avatar
Question how to shave cab seam?
Hey guys.. just wonderin if any of you have trucks with shaved cab seams (mostly the roof one), and if you know how it was done, or how you did it if you did it yourself. Looking into how to do this properly, thanks!
CANADIAN CONNECTION
love it loud is offline   Reply With Quote
Old 11-30-2004, 12:50 AM   #2
bigblock73
yeller
bigblock73's Avatar
I had mine welded shut and ground smooth. Jonboy did his, and he used automotive adhesive I believe...perhaps he will chime in and tell you more (I forgot exactly what he told me way back when).
Here is a pic of mine.
bigblock73 is offline   Reply With Quote
Old 11-30-2004, 01:12 AM   #3
1972C10
1972C10's Avatar
I kinda wish i had done that to mine Pretty clean.
1972C10 is offline   Reply With Quote
Old 11-30-2004, 01:38 AM   #4
love it loud
welded shut? i'm pretty good with a mig.. shaved firewall, door handles, etc., but this seam is pretty wide and deep.. would take A LOT more than the small, quick tacks that sheetmetal can handle.. this must have taken HOURS to build up the weld to fill in the seam completely!?
CANADIAN CONNECTION
Old 11-30-2004, 01:43 AM   #5
1972C10
1972C10's Avatar
You get rid of your cargo light Jeff?
Old 11-30-2004, 01:55 AM   #6
bigblock73
yeller
bigblock73's Avatar
Yeah, I sold it to Ocbaud.
Old 11-30-2004, 01:56 AM   #7
love it loud
hijacked thread..........
CANADIAN CONNECTION
Old 11-30-2004, 02:00 AM   #8
1972C10
1972C10's Avatar
Yea ...... I just noticed the hole under the seatbelt bolt For the switch. I just put a cargo light on my 85 and i noticed that pre 80 trucks have the switch below that bolt hole in the 80s they went to putting it above it >. I guess they figured out it was kinda obstruced with shoulder belts.
Old 11-30-2004, 10:57 AM   #9
love it loud
alright then.. thanks for the initial help until this got taken completely off topic... and my second question regarding this thread was ignored.
CANADIAN CONNECTION
Old 11-30-2004, 11:29 AM   #10
bigblock73
yeller
bigblock73's Avatar
Calm down, I don't think 1972C10 meant to hijack your thread with the intents of pissing you off. This kind of small talk happens on just about every forum on the net.
As far as saying which method is best, I would prefer welding it shut, but I am by no means a body man and I really have no experience with automotive adhesive...it could be just as good as welding.
Jonboy is knowledgable in that area, maybe PM him and find out if he doesn't see this thread.
Old 11-30-2004, 12:22 PM   #11
Jonboy
Slots go on anything!
The adhesive I usedis a two part epoxy that we use to bond panels on with. The key to using this, or even welding the seam, is to make sure the surface is clean. The factory used a seam sealer that is semi flexible. You will need to clean all of that out, down to bare metal. If you are going to weld the seam, do that now. I put the panel bond right in the seam, and used a bondo spreader to smooth it out. Then I used masking tape to hold it in place for 24 hours. After it is cured, work it like normal, and finish as needed. It also looks like using a fiberglass reinforced filler such as Marglass would work as well, since it is not a structural area, nor is it flexible. I filled the drip rails at the same time, and welded those holes.
1974 Jimmy- 5.3/4L80e/NP241
Thread Tools
Display Modes
