Old 11-30-2004, 06:14 PM   #1
Dick Dale
Excelsior, You Fathead.
Dick Dale's Avatar
Proportioning Valve Question
Today must be brake day or something. I need a new prop. valve and the old one is discontinued. What do I buy and how do I hook up the brake light wire on the new one. Thanks.
Go Navy. The Sea Is Ours.
Budget 350 Build
http://67-72chevytrucks.com/vboard/s...38#post2264638
Dick Dale is offline   Reply With Quote
Old 11-30-2004, 06:22 PM   #2
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
What exactly is it for?
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 11-30-2004, 11:11 PM   #3
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
mothertruckers has them. i know that for sure. new and used
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 12-01-2004, 03:21 AM   #4
68speedalert
Semi-Senior Member
68speedalert's Avatar
How do you know you need one?
A Prop valve does more than one thing. It delays the front disc from applying compared to the rears. 4 wheel drum Prop valves don't.
Second function is in case of a catastrophic failure in the front or rear circuits, a block inside slides and blocks the fluid from continuing out the bad line. It then sets the 'brake' light on telling the driver there is a problem. (like he won't know from his foot going to the floor).
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 12-01-2004, 04:02 PM   #5
Dick Dale
Dick Dale's Avatar
The PO left the brakes a mess and I decided since it doesnt run yet, to change all the brake components before the engine this summer.
Budget 350 Build
Old 12-01-2004, 08:16 PM   #6
71Chev
71Chev's Avatar
You'll find a replacement here. If you are staying with stock brakes, you need the disc/drum prop valve. Brake warning light wire hooks up just like yours does now.
http://www.gmcpauls.com/Brakes&Steering.htm
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Thread Tools
Display Modes
