Old 12-06-2004, 07:37 PM   #1
racer94
heads,crank,roller rockers,ect.ect....
set of brand new wiseco forged dome pistons for sale..they are for 4.125 bore,5.7 rod and have the wavelock clips..1.135 comp height..good pistons here..$200
i have a brand new scat crank,3.48 stroke for 350 chevy..std/std journals..nice peice...$190
set of gm .060 over pistons and gm rods.....$50
i have a 3/8 set of roller rockers 1.5 crane gold..also have a set of gold crane stud girdles with poly locks..$225 for all
have a solid cam and new solid lifters..295 duration with a 537/555 lift....$80
have a set of 487 heads,ported professionally,ss 2.02/1.60 valves,crower triple 600 lift springs,screw in studs,good set of heads for $300
double roller timing shain with tri set crank gear---$25
set of coustic 12'' subwoofers,good shape..$60
have a chrome carter high volume fuel pump ill take $50 for
mallory dual point distributor,tach drive,no cap....$40
hei distributor with aftermarket module,mallory hot coil,accel cap..$60
all stuff i need out of the way..i will ship anything listed through ups at buyer expense..thanks
racer94 is offline   Reply With Quote
Old 12-06-2004, 09:39 PM   #2
pat
pat's Avatar
What will those heads work for?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 12-07-2004, 12:11 AM   #3
racer94
heads will work for any small block chevrolet.....thanks
Old 12-07-2004, 01:26 AM   #4
breeh
Recovering 67-72 Addict
breeh's Avatar
Are the Crane Gold rockers the extruded roller or the pro series? How much time on them? Thanks
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 12-07-2004, 01:55 AM   #5
racer94
they are the extruded roller....they were ran about 4 times in a circle track car..exellent shape,have the poly locks and the gold crane stud girdles that go with them..
Old 12-07-2004, 03:03 AM   #6
breeh
breeh's Avatar
Thanks for the reply, PM sent...
Old 12-07-2004, 12:36 PM   #7
racer94
reduced price on rockers....
Thread Tools
Display Modes
