Old 12-07-2004, 02:21 PM   #1
r0lf-
Hotwheels?
r0lf-'s Avatar
Progress shots. *56k warning*
Sittin Pretty with the front down another 1 or 1 1/2 inches or so. Not gonna be able to notch the rear today, but I am gonna flip it and only do a 1" shackle. Ill just be careful so I dont bottom out too much.
Its got a really good sport truck rake to it right now.
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 12-07-2004, 02:23 PM   #2
cochino12
It followed me home?
cochino12's Avatar
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-07-2004, 03:42 PM   #3
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
I think it sits perfectly, myself. Very Cool.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 12-07-2004, 04:04 PM   #4
r0lf-
Hotwheels?
r0lf-'s Avatar
yeah, it sits pretty good for the front being where it is. But when I return my spindles Im prolly ordering some 3" springs in place of em. So the rear has to go down.
Old 12-07-2004, 06:18 PM   #5
TIMSPEED
TIMSPEED's Avatar
Hey do me a favor. Measure from the ground to the fenderlips right now. Cuz it looks like your truck is sitting like mine right now. LOOKS GOOD!! So, you're going to be 6/8 in the end??
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 12-07-2004, 06:29 PM   #6
corn
??? What do you have in the front now? No spindles? It sits really nice the way it is...corn
corn is offline   Reply With Quote
Old 12-07-2004, 06:43 PM   #7
r0lf-
Hotwheels?
r0lf-'s Avatar
The front has 2.5" spindles and I cut a coil out. Soooo, im not sure what kinda springs were in there. They MIGHT have been stock, who knows. I started putting on my WC spindles last night and got one on, remeasured, and it was like 1/4" higher, I took a look and placed the spindles side by side and it turns out I already had lowering spindles on there. Prolly really old Belltech ones that werent marked. So im returning the spindles and getting some 2" or 3" springs. Im just finishing up the flip right now. Unless I can preform a miracle, I dont think the notch will be done today.
Its gonna be tight in the back for a while. Looks like only 2" of clearance.
More reason to get that notch in and springs on! Its quite a gratifying experience ripping the entire suspension apart. God ive never been so dirty in my life.
More pics coming soon!
Gonna be riding cali crawl sytle for a bit
Old 12-07-2004, 06:58 PM   #8
TIMSPEED
TIMSPEED's Avatar
That's how I was...dropped 5" in back with no drop in the front, hahaha.
See Them Here
Old 12-07-2004, 10:40 PM   #9
r0lf-
Hotwheels?
r0lf-'s Avatar
Holy $hit! Im MAD cali crawl. Im thinking I have like 4" in the front if im lucky, now 7 or 8" in the rear. Gotta get that notch in asap, I have like 1.5" of clearance. Bottoms out on everything. So, spindles are going back and 3" springs are going up front. 5-8 here I come.
I get pics of the cali crawl tommorow in the light after I get all the grease off the truck.
Old 12-07-2004, 10:49 PM   #10
low 84
low 84's Avatar
looks sweet
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 12-08-2004, 12:32 AM   #11
TIMSPEED
TIMSPEED's Avatar
Did you take your bumpstop brackets off the back, completely? What do you have in the back, flip+shackle, right? What shocks are you running? With my 5" DJM Flip in back, and DT Shocks, Me and my friend (200 & 250 pounds) BOTH jumped on the bed and the MOST it moved was 2", STILL a GOOD 2" of clearance between the frame & axle. Do you have a 6 or 8 leaf pack in the back?
See Them Here
Old 12-08-2004, 01:48 AM   #12
r0lf-
Hotwheels?
r0lf-'s Avatar
I have the light duty leaf pack, and a shackle, it sat ON the frame, so Im halfway done with the notch and it, like you said, doesnt move more than 2". Im tucking a TON of tire. Its gotta be atleast 7" drop back there. I dunno if the leaves are drop leaves or what, but its low. Its a WC flip kit too, but its only rated to 5 inches. Time to go throw some more sparks and get this bugger finished up.
Old 12-08-2004, 02:57 AM   #13
TIMSPEED
TIMSPEED's Avatar
I'm tucking a TON of tire. Its gotta be atleast 7" drop back there. I dunno if the leaves are drop leaves or what, but its low. Its a WC flip kit too, but its only rated to 5 inches.
They HAVE to be drop leafs, because I have a little taller tire than you, and with a flip&shackle, it wouldn't tuck at all.
See Them Here
Old 12-08-2004, 03:00 AM   #14
ocbaud
Garage Queen Material
my old 28" tall tires tucked a little bit with just a flip kit
ocbaud is offline   Reply With Quote
Old 12-08-2004, 03:01 AM   #15
r0lf-
Hotwheels?
r0lf-'s Avatar
Yeah, im tucking like 3 or so inches of tire. Almost to the rim, I mean its LOWW. I made a dumb mistake though when putting on the passenger side notch. Cut the brake line. Would a temp fix by taking some rubber line and using it where It got cut be such a bad idea?
Old 12-08-2004, 11:38 AM   #16
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
... Would a temp fix by taking some rubber line and using it where It got cut be such a bad idea?
Brake lines run at around 2000-3000 psi when you stomp the pedal. A rubber line hose clamped in place would blow off in no time leaving you with no brakes. You need to replace that line and not drive your truck until you do.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 12-08-2004, 02:25 PM   #17
8t5Silverado
I agree, fix it right.
You'd hate to lose your truck (or hurt yourself or someone else) to something so minor.
Old 12-08-2004, 03:00 PM   #18
r0lf-
Hotwheels?
r0lf-'s Avatar
Yeah, I was just taking a look at it since Im finally finishing my notch. I ran out of steam last night since I worked on the beast for like 12 hours. Can I just run down to the parts store and buy some line and a line bender and run some more? Never replaced it before but I cant imagine its too hard. Run the new line and bleed it, right?
Anyhow. I think my rear bumper is like 8 or so inches off the ground. Its AWESOME.
Old 12-08-2004, 03:05 PM   #19
TIMSPEED
TIMSPEED's Avatar
My PINCHWELD isn't even that low!
See Them Here
Old 12-08-2004, 09:35 PM   #20
corn
Wow. that is LOW! I have light duty leafs on mine with one leaf removed, a flip kit & rear shackles & it sits maybe 2 1/2" over the frame with the box off. Im betting that you have drop leaf springs on yours too...corn
Thread Tools
Display Modes
