Old 12-09-2004, 04:18 AM   #1
blaserman
blaserman's Avatar
Question Heat????
HOW DO YOU PEOPLE IN THE MIDWEST GET YOUR TRUCK TO GIVE HEAT QUICKLY?? I HAVE A 86 K5 BLAZER AND LIVE IN MARYLAND. WE HAVE ONLY HAD TEMP IN THE MID 30'S SO FAR AND IT TAKE ALMOST 15-20 MINUTES BEFORE I CAN GET ANY GOOD HEAT. RUNNING A 180 THEMO.
blaserman is offline   Reply With Quote
Old 12-09-2004, 07:56 AM   #2
smokinn
smokinn's Avatar
Cardboard cut to fit in front of the radiator or you could try a engine heater.
Jason
smokinn is offline   Reply With Quote
Old 12-09-2004, 09:39 AM   #3
74Pumpkin
Insert witty comment here
74Pumpkin's Avatar
Your T-stat might not be working properly. It might be stuck Partially open and needs changing out.
So many trucks, So little time!
74Pumpkin is offline   Reply With Quote
Old 12-09-2004, 10:47 AM   #4
mhicks
mhicks's Avatar
I have had nothing but bad luck on the cheaper thermostats. Try and buy the best they have when you go to the auto supply store. That is the same problem I have had on several different type of vehicles. They would last about a year and then the heater would take foreever to get warm. Replace the thermostat and it would fix the problem.
mhicks is offline   Reply With Quote
Old 12-09-2004, 02:20 PM   #5
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
Why are you yelling?
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 12-09-2004, 03:47 PM   #6
Joey-T
Probably because he's cold!
Joey-T is offline   Reply With Quote
Thread Tools
Display Modes
