Old 12-10-2004, 11:04 AM   #1
spencra
This, is my BOOMSTICK!
spencra's Avatar
headlights don't work??
I just can't seem to get my headlights on. I turn on the light switch and all of the other lights work except the headlights. I replaced both with new headlight bulbs and still nothing. I think that I checked the wiring and it all looks good. I thought that it might be the ground (wire that goes to the fender but that looks OK). I looked at the fuses and there is no fuse for headlights, unless i'm missing something here.
Does anybody have an answer for this problem?
Thanks in advance,
Larry
Larry
Got rid of my projects for now.
1980 Jeep CJ7
1998 Nissan Sentra (my car)
2001 Toyota Sienna (wife's, of course)
spencra is offline   Reply With Quote
Old 12-10-2004, 11:08 AM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Dimmer switch.
Pull the connector to it and jumper it to see if that is the culprit.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 12-10-2004, 11:25 AM   #3
spencra
spencra's Avatar
Hey CPNE, by dimmer switch do you mean the high beam switch on the floor or the actual light switch? If you do mean the light switch, what is the easiest way to get it off?
Sorry, I know that it's probably a stupid question.
Larry
1980 Jeep CJ7
Old 12-10-2004, 11:28 AM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
hi-lo beam switch on floor
Old 12-10-2004, 11:43 AM   #5
spencra
spencra's Avatar
Thanks CPNE, that's what I thought that you meant.
I think that you might be right on that one. I could swear that when I hit it a couple of times a couple of weeks ago that they briefly turned on. I thought that maybe I was just seeing things though.
Larry
1980 Jeep CJ7
Old 12-10-2004, 11:57 AM   #6
flip66
flip66's Avatar
thats the problem mine did the same thing Pull the carpet back 2 screws hold it to the floor then just unplug it really easy and cheap to replace
1998 Pontiac Grad Prix GTP
1969 C10 396 TH400 3.08 posi
flip66 is offline   Reply With Quote
Old 12-10-2004, 12:00 PM   #7
spencra
spencra's Avatar
thanks flip66, I suppose those connectors are really sensitive huh.
Larry
1980 Jeep CJ7
Old 12-10-2004, 12:28 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
not so sensitive, but after 305 years of getting kicked and soaked, they tend to go bad.
Look at the connections real good. The harness plug may be junk too.
Old 12-10-2004, 01:04 PM   #9
dons454s
dons454s's Avatar
Mine did the same thing kinda turnt an ugly shade of green and rust down there. New plug and dimmer switch fixed it right up. I would be driving and try to switch from high to low or the other way and loose the lights all together.
dons454s is offline   Reply With Quote
Old 12-10-2004, 03:23 PM   #10
spencra
spencra's Avatar
Yup, that seems to have been the problem. I took the old one out and put a new one in. At first it didn't work, I took it off again and blew some dust and dirt and stuff out of the terminal. I had to repeat this step several times before it finally worked.
Thanks alot CPNE and the rest of you guys. You're the greatest
Larry
1980 Jeep CJ7
Thread Tools
Display Modes
