12-11-2004, 05:35 PM | #1 |
Keep On Truckin'
Pictures of Vintage Air Super-Gen II mock-up
I was dreading this since it is not the Sure-Fit system but the mock-up was straight forward and went very well. Modified two of the three brackets provided with the kit and welded them in place along with the third stock bracket. Its off to the hose shop next week to have the A/C bead-lock fittings crimped onto the hoses.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
12-11-2004, 08:01 PM | #2 |
FUEL CELL GURU
As you probably already know, put some witness lines on the crimp collars and the hose so that all the fittings end up pointing the right way. This will prevent twisting the lines for hookup. Clear as mud?? Later, Mark
12-11-2004, 08:06 PM | #3 |
That looks good. I was thinking of doing something similar. Are you going to use the stock controls or something different?
Edit: for stock type controls I mean the OEM control plate/unit.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
12-11-2004, 08:18 PM | #4 |
Keep On Truckin'
Mark: yeah I learned the hard way many, many years ago about hose alignment. But, thanks for reminding me.
68LSS1: no, not going stock; see picture below
12-11-2004, 09:44 PM | #5 |
Oh yeah, I love it. I was trying to keep away from using that control panel because that is going to make me want to shave the dash. But that looks good. I guess I got something else on the to do list. I can't tell by the pictures but could I slide it towards the drivers side some if I did the same thing?
12-11-2004, 10:38 PM | #6 | |
Keep On Truckin'
12-12-2004, 02:05 AM | #7 |
All Praise RANDY!!
A little off subject, but what type of insulating material is that? By the way, looks good, nice fit, and thanks for the pics, I was wondering how that gen II system would work... I want to do the same.
12-12-2004, 02:48 AM | #8 |
Looks good! Show us some more pics when you get further along. How cold will those units blow?
Thanks for sharing the photos.
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
12-12-2004, 10:36 AM | #9 | |
Keep On Truckin'
12-12-2004, 11:13 AM | #10 |
PROJECT 7DEUCE
Looks like I need to put a couple of more mods on the never ending project truck I seem to own..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-13-2004, 12:22 AM | #11 |
Junior Member
Is the Gen II the one that uses servos instead of vacum pods? Which model are you using? I'm thinking of putting one in the wife's '63 and also in my Coronet.
63 C10 70 Coronet R/T 67 C10 70 Dart Swinger 71 K10 |
12-13-2004, 01:31 PM | #12 |
Ttt
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
12-13-2004, 04:34 PM | #13 | |
Keep On Truckin'
I'm using 61005 Series Gen-II Super Cooler with heat, cool & defrost model. It comes with four A/C outlets from the evaporator so I'm probably going to tie two of them together for the center duct or just block one off.
12-13-2004, 06:56 PM | #14 |
MOCWON .. WHERE DID YOU BUY YOUR KIT FROM & HOW MUCH WAS IT??? JOHN
12-13-2004, 08:17 PM | #15 | |
Keep On Truckin'
1202 A West Keystone Expressway Sand Springs, OK 74063 918-241-6333 $1,010.47 including shipping plus the cost of a few fittings and hose adapters for the GM vent balls. I didn't buy the Sanden compressor since I'm using a GM compressor and serpentine setup.
12-13-2004, 08:47 PM | #16 |
turnin wrenches
i was just curious if those vents came with the kit or if yours was an a/c cab to begin with? btw looks like you have done a top notch job there congrats!!
BBB
"three can keep a secret if two are dead" -unknown hell's angel- D.M.C. -FF- 68 SWB full frame off (project ol skool) 2000 s-10 formally bagged but now my daily driver... |
12-13-2004, 11:12 PM | #17 | |
Keep On Truckin'
It was a non-AC cab that I converted to an AC cab by cutting the holes. The vents were included in the price.
Thread Tools | |
Display Modes | |
