12-12-2004, 09:28 PM | #1 |
Garage Queen Material
i broke my truck
went to the track tonight. i believe i collapsed a lifter. i pulled the valve cover on that side and the pushrod was just chillin below the valve guide and with a flashlight pointed in there, i cant see the lifter.....
so.. i get to pull my intake this week |
12-12-2004, 10:36 PM | #2 |
Not good...did you get to run it down the track at all?? |
12-12-2004, 10:56 PM | #3 |
yeah,it was really slick and it spun through all 3 gears and i didnt get traction till half way down the track.
ran a mid 16 |
12-12-2004, 11:27 PM | #4 |
seems like your truck has been mad at you ever since the posi install... you gotta love that good GM feeling.
Youth soon passes away, but immaturity can last a life time. |
12-13-2004, 12:17 AM | #5 |
BAD BOW-Silverado XST
One more reason to go to roller lifters!!!!
12-13-2004, 12:20 AM | #6 | |
so guys, am i gonna need to replace all the lifters? and if not, where is a good place to buy just 1 lifter?? |
12-13-2004, 01:03 AM | #7 |
Project92 SWB stepside
I would think that one would be fine but as cheap as they are??? Go roller or a solid cam to boost the power!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
12-13-2004, 01:10 AM | #8 |
Right turn Clyde
Depending on what all happened (damaged) you may need to replace the cam also.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
12-13-2004, 02:22 AM | #9 |
california fill
in my experience- its unlikely that you'll be as lucky as to just have to replace a lifter.. if it is the case- you can buy a single lifter at any machine shop, should only be a few bucks. I wouldnt replace any of the others if they're fine. It will just make the chance of wiping out a cam lobe that much better. Replace the one thats bad and break it in and make sure all the other lifters get put back on their appropriate lobe during reassembly.
pc |
12-13-2004, 02:22 AM | #10 |
I doubt he would ever manage to set a solid cam ..
Possibilty you can get away with putting in one lifter you should be able to buy them individually But like stated the cam could be damaged |
12-13-2004, 02:28 AM | #11 | |
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
12-13-2004, 02:34 AM | #12 |
so, what are the chances of me needing to replace the cam??
12-13-2004, 03:39 AM | #13 |
driving is in my blood
50/50.....pull the intake and find out
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
12-13-2004, 10:15 AM | #14 |
what made you think you collapsed a lifter and not wiped a cam lobe? what kind of diagnostics have you done so far? stop asking questions and go pull the intake and find out, lol
12-13-2004, 10:52 AM | #15 |
BeWarE tHe eViL CrAnkTOe!
Hey Eric.....ever hear of LIFTING off the gas when you start spinning/? lol When you start spinning there is no reason to even keep trying to get a good # cause its just not gonna happen if your midway through 2nd or 3rd and still spinning. just let off and save your truck parts from the damage that has been done already. Patience grasshoppah.
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
12-13-2004, 10:53 AM | #16 |
Not to mention the fact that you should have called me, I was gonna go and see if they would let me run the truck foolio! But I wasnt feeling the best anyhow.
12-13-2004, 11:29 AM | #17 | |
i took off the valve cover, and actually the retaining nut to a rocker arm had come off, i have no clue how either. the pushrod was in the place it was supposed to be but it was very very far down in there. i took a flashlight and saw a lifter on one side, but the other lifter looked like it was missing. |
12-13-2004, 12:17 PM | #18 | |
Lifter missing as in you saw an open lifter hole? Thats frightening, because lifters dong go that far down in the holes before they touch the cam...
Daily Driver: 1992 Blazer dropped on rallys Project: 87 GMC shortwide, About to get a little boost |
12-13-2004, 02:14 PM | #19 | |
12-13-2004, 02:55 PM | #20 |
i just took some pictures and looked again, the picturees didnt come out well because hte guide plates are in the way but.....
yes, the lifter has gone missing. i was looking down into where the lifter should be, and i saw a cam lobe.... |
12-13-2004, 02:56 PM | #21 |
Smooth Move Ex Lax
12-13-2004, 03:01 PM | #22 |
12-13-2004, 03:02 PM | #23 | |
12-13-2004, 03:29 PM | #24 |
sounds like you just lost the rocker arm nut, then it slung the push rod and lifter out of the hole. no big deal really.
12-13-2004, 03:54 PM | #25 |
I always said you had a nut loose
Thread Tools | |
Display Modes | |
