12-14-2004, 02:20 PM | #1 |
Valve Cover Oil Cap/Grommets
My passenger side valve cover has on it an oil cap towards the front of the cover (the rear has the flame arrestor). Since the oil cap is a pretty sloppy fit......doesn't fit very tight......I was wondering if there is some type of grommet that could fit there that would seal up the hole in place of the oil cap? Or do they make oil caps similar to the one in the cover? The A/C compressor and mounting brackets sit right on top of that area so there is only an inch or so of room between the cover and brackets. And I do not want to replace the original valve covers for aftermarket. Any ideas what could be used? Thanks for any help.
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air 2000 Harley...Wide Glide |
12-14-2004, 02:36 PM | #2 |
HUH?????
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
12-14-2004, 03:20 PM | #3 |
CST P/N 8072 at Autozone. Oil filler cap.
12-14-2004, 03:22 PM | #4 |
Lovin' Life in Miss.!
There is an oil filler extension available also. Dunno a part #. Was eyeballing them at our local speed shop.
The truck... you hear that? No really, you did hear that?!!! |
12-14-2004, 03:45 PM | #5 |
Crusty,
Thanks............I'll check into that. The ones they've given me before were too tall to fit but I'll try the one you mentioned.
12-14-2004, 03:54 PM | #6 |
oil cap
Oil caps, breathers and grommets are not the same for steel covers and aluminum covers. Maybe you have the wrong grommet and or cap.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
12-14-2004, 04:54 PM | #7 |
My gm parts book says 71-72 ser 10 thru 30, blazer (exc. b.b.) 10110859
cap asm , oil filler (2" dia) rubber |
12-14-2004, 09:17 PM | #8 |
Yea, my 72 has the 2" rubber oil cap on both valve covers. A PCV on the drivers side, and hose going to the air cleaner base on the pass side to evacuate vapors from the crankcase.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
12-15-2004, 12:08 AM | #9 |
Its Magically Delicious
Most of the venders carry the stock oil plugs for the valve covers ... couple bucks
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
Thread Tools | |
Display Modes | |
