Old 12-16-2004, 01:48 AM   #1
roadking
storing bed ?
i want to take my bed off my truck (swb) and store it in a vetical position with the front of the bed toward the floor sitting on a couple of padded 2 by 4. has anyone done this? or will it be to hard on my sheetmetal?
71 C10 SWB
BLACK AND WHITE
350 CRATE TH350
ENJOY LIFE
roadking is offline   Reply With Quote
Old 12-16-2004, 07:39 AM   #2
JimKshortstep4x4
Smile
The tops of the bedsides are really strong but the lower parts are not. Standing the bed up can be where you might damage it if you put weight on the lower bedside sheet metal. The front lower corners will bend fairly easy.
Also, with 2x4's under the front the bed could be tipsy.
Is there a reason to stand it up for storage, (storage room problem)?
We built a wood frame with rails to pick up the cross rails and stored the bed outside. The frame is tipped approximately 3" to insure no standing water in the bed floor.
Although it can be done I would not store the bed vertically.
Jim
Old 12-16-2004, 12:13 PM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
If you block it on the edges or make a box frame,so the weight is on the edges and not in the middle and though a rope around it to the wall so it doesnt tip over on you. you should be fine.
sneakysnake is offline   Reply With Quote
Old 12-17-2004, 11:35 AM   #4
61corv
i had mine sitting upright on 2 old tires for a year with no damage...in the back of my exwifes garage. she got the house - i finally got the truck. good trade.
69 swb, slammed, shaved and never finished.
61corv is offline   Reply With Quote
Old 12-26-2004, 11:40 PM   #5
68gmcdually
68gmcdually's Avatar
Mine has been standing on it's nose for a year as well, the only damage inflicted was from our snowplow tapping the side.
James Bellwood
1968 930 Extend-A-Cab Dually 5.7l, 5 speed,
68gmcdually is offline   Reply With Quote
Old 12-27-2004, 11:46 AM   #6
Vince M
Vince M's Avatar
If you want to save even more room take the bed apart. It's easy and you know you want to put shinny new stainless steel bolts in it when you put it back together.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Thread Tools
Display Modes
