Old 12-16-2004, 09:06 PM   #1
benscool1
benscool1's Avatar
Brake Problems in 84?
The problem just started this week, we put a new rear brake line on a few weeks ago because it busted when I started towing another truck so we fixed it in the parking lot of the autozone about a mile from where I bought the truck. Now suddenly whenever I push the pedal down there is nothing for about the first inch, but once I get past that, suddenly the wheels lock up, and sometimes it seems like its just the drivers side rear. I don't really mind it because it doesn't happen all the time, or at least not as bad but I have new tires and I don't wanna pay for new ones! Its not using or losing fluid, and I checked and saw no leaks underneath. What could it be? cylinder? proportioning valve? master cylinder or booster?
Ben
84 C10 Silverado
14 Silverado Z71
benscool1 is offline   Reply With Quote
Old 12-16-2004, 11:49 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I had a car that did that once. It was fluid leaking around the seal on the axle.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 12-17-2004, 07:13 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Did you bleed the system after replacing this brake line?
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-17-2004, 07:35 PM   #4
Apache
Apache's Avatar
Make sure all the air was out of the fluid. If you bled them, still a chance they may be some in the lines. They can take a while to bleed sometimes, and other times they are really easy to bleed.
54 Chevy Bel Air 4dr powerglide
54 Chevy SWB
58 Chevy Big Window SWB Fleetside project
58 Chevy LWB 235/4spd
76 Chevy Nova 350/TH350 4.88's *10kmiles on "new" engine
79 Chevy 4x4 SWB 350/4spd 3/4 ton
81 Mazda RX7
84 F@!d Mustang
96 F@!d Ranger 2.3L/5spd
Apache is offline   Reply With Quote
Old 12-17-2004, 08:53 PM   #5
benscool1
benscool1's Avatar
Yeah, but it was a quick job, and all we did was that one wheel. And we hadn't had a problem til now so it didn't occur to do it again. Do we need to do the entire system or just that one wheel?
Ben
84 C10 Silverado
14 Silverado Z71
Old 12-17-2004, 09:45 PM   #6
Apache
Apache's Avatar
Try doing the whole system again. You said that one wheel is locking up right? That could be why its locking up...the other 3 have air in them and the brakes arent being applied as much. Letting most of the braking being done by that 1 wheel.
54 Chevy SWB
81 Mazda RX7
84 F@!d Mustang
Thread Tools
Display Modes
