Old 12-24-2004, 06:04 PM   #1
XXL
Seņor Member
XXL's Avatar
Looking for pics/schematic of brake pedal assy
If you've got any pics or exploded diagram (or even if you can describe the assembly) for the brake pedal, I'd appreciate it. I've got the steel pedal but nothing else in my hand... I know there are some plastic bushings, but what holds it in the bracket? Is there a pin that goes all the way through? Or??
XXL is offline   Reply With Quote
Old 12-24-2004, 11:03 PM   #2
SCOTI
SCOTI's Avatar
Kenneth, I have a pedal assembly somewhere around my stash. It's a clutch set-up but should give you an idea. If someone doesn't beat me to it, I can put up some picks tomorrow evening & see if that helps you. Scot
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-25-2004, 01:27 AM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
There is a pin that goes all of the way through and the pin has a tab that has a hole in it for a bolt to hold it to the mounting bracket. A manual transmission brake pedal and the automatic brake pedal are the same, the clutch pedal is just mounted into the bracket on the same pin.
piecesparts is offline   Reply With Quote
Thread Tools
Display Modes
