Coil springs: 1/2 vs. 3/4 ton?
I'm not "into" lowering trucks- I apologize to those who are!- but my '69 GMC has the same, original coil springs it came with. It doesn't sag at any corner, so it's OK, but I DO use it to go in the woods & go hunting and haul firewood, etc. Here's my question: will 3/4 ton coils work under it and would they possibly give me a little lift, too? Looking at aftermarket suppliers, there doesn't seem to be any, IF any, difference in prices, so...? Thanks, Bud
its all about the +6 inches
They would gove a stiffer ride, and might get you 1/2 an inch.
Junior Member
Hi Bud
Planning on doing the same, cost per coil from NAPA is $91.56 Stock id dia Load Hgt coils load Rate Free Hgt Part Number .812 10.00" 7.92 2950 1016 12.94 PN 277-1752 77 BB .830 10.00" 8.00 3841 1060 13.61 PN 277-2074 I'm "guessing" that if you have a SB instead of BB we will see a little lift in the front end. I'll leave it to the pro's on the board who may have more than "book info" to verify. If we don't hear anything, I plan a 77 front end swap soon and plan on adding the BB springs. I'll post my results WC
1970 GMC 2500 1994 S10 SuperSport 2000 16' Customweld FishN Boat |
Junior Member
How about rear leaf upgrades for a 70 3/4 ton while we are at it? I have not used blocks for anything since I quit playing with LEGO'S ;-)
WC
#5 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
If so, that's rape. A set of stock replacement coil springs should cost 60-90 bucks a pair, not each.
Junior Member
Yah its is list price, just a reference, back to the original ???, what do ya KNOW about the swap? We're lookin for real world results here. Does the swap of BB springs add lift? If not, how?
WC
If you want a lift use some out of a 1 ton truck.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
I've got a pair of 3/4 ton coils from a '66 truck that I once installed in a '72 longbed I drove in high school. That truck is history, but I saved the springs. Don't really know why. I guess I've had them for ......good grief!.......19 years.......Man, I'm gettin' old. If anybody wants them, I'll sell them for $60 for the pair plus shipping.
[FONT=Georgia] If nothing else, we can all serve as a bad example. ![]() We don't know what we don't know. ![]() The world needs ditch-diggers too. ![]() |
Look at a set of springs for the same year Suburban. They were rated higher than a 1/2 ton, but less than a 3/4 ton, so they will give you more weight capacity without the rougher ride.
#10 | |
Got Light Emitting Diode?
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
Hmmm....LMC offers a front/rear set for C20 w/396-402 engines for $130 + s&h...maybe that's something like I'm looking for? My GMC is a 1500 Series (with a 283), what the parts store equates with a C10, so these should work with my truck? BUT, if I only get 1/2" lift, it's not worth it...I'd like a little more, if possible, on all four corners.
Regarding how old the truck is, wear & tear AND putting C20 springs under it, maybe there'd be more lift than we're thinking? Also, the ride is already rough with the all-terrain tires right now; when hunting season is over (end of April), the 60's go back on! Westcoaster, I'd like to know your results on the big block springs! I'm not looking for a "rake" but a lift on all four corners, as I said previously. I may not get anything done until after hunting season, any way, but at least I can get it ready for next season...and I'll be working on the club's roads until then, so I'll need it. Hmmm, in that case, the 60's may NOT go back on...? Last edited by bud45; 12-31-2004 at 07:17 PM. |
Thread Tools | |
Display Modes | |
