Old 12-30-2004, 11:11 AM   #1
tphsmith
still buypickupparts
tphsmith's Avatar
wiper delay switch
there is one on e-bay right now foe 73 to 83 chevy truck I cant figure out how to send the link here for you all to see it but, will this work on trucks with a little wire harness modification for wiper delay here is the e-bay item numberItem number: 7943075482
Its Gonna be a Great Day, I woke up this Morning.
72 SWB Fleetside freshly painted. putting a 94 LT1 with
700R4 tranny lowered 4 in the front 6 in the back
81 chevy half ton 350
89 Silverado 4x4 going ta church truck
tphsmith is offline   Reply With Quote
Old 12-30-2004, 03:09 PM   #2
smokekiki
Mike
smokekiki's Avatar
have You read this post? http://67-72chevytrucks.com/vboard/s...d.php3?t=32017 The switch on E-bay will not look stock.Not sure if it could be made to work.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 12-30-2004, 05:54 PM   #3
tphsmith
tphsmith's Avatar
modify the wire harness
would it be possible to cut the switch offthat is on it now and interface it to a factory 67-72 switch?????????????
Old 12-30-2004, 06:06 PM   #4
mr402
It takes a lot of work but you can make the switch look stock. First you'll need to take apart the delay box and look at the switch. Usually it's a variable resistor with a switch as one assembly. When I did mine I had to go to an electronics shop to get a replacement variable resistor. Still had to modify the switch. Drilled and cut a bolt to fit over the shank to enlarge it to the proper size. Wired the switch in and tucked the box behind the dash. No detail pics but here's one of the finished product. The wiper delay switch is on the right. Switch on the left is for the fog lights (need them here in Oregon). LEDs in the vacuum pod let me know I have the fog lights or wiper delay on.
mr402 is offline   Reply With Quote
Old 01-02-2005, 12:00 PM   #5
Mr402,That is way impressive.I`d like to get more detail on that.A worthy upgrade on these trucks.I had an aftermarket,under-dash delay wired into a truck one time.Don`t see them around,now that intermitent wipes are common-place in most vehicles
Thread Tools
Display Modes
