Old 12-30-2004, 03:18 PM   #1
locab36
locab36's Avatar
How to check fuel guage??
Just picked up a 84 Chevy short wide box. Inline 6 replaced w/305, factory turbo 350. Fuel guage isn't working. Driving it home reading under half tank and stopped to put in some gas. After filling 2 gallons the tank was full and the guage didn't move. Took the dash guages out and checked the pink wire from the sending unit, it shows a little over 90 Ohms on my multimeter. I have 12V+ on one side of the printed circuit and the input from the sender but there is a third (ground?) and I don't know what it is. If I take the guage out How can I check it?
John
Locab36
1936 low cab 1/2 ton
1956 BMW R25/3
1968 Moto Guzzi V7
1969 BMW R100/2
1986 Silverado SWB
2007 Harley FLHTP
2011 GMC SWB 4x4 Z71
http://www.flickr.com/photos/locab36...7623329816080/
locab36 is offline   Reply With Quote
Old 12-30-2004, 06:44 PM   #2
Stingray42
Woot.
Stingray42's Avatar
mines gone to hell too... dif problem (mien read waaaay fulll... like 3oclock position) but this may help me out too (and i may be able to find something for ya too) thanks
Clarkson
96 Chevy RCLB 4.3 2WD
Stingray42 is offline   Reply With Quote
Old 12-30-2004, 07:15 PM   #3
longhorn71
longhorn71's Avatar
ttt.my blazer reads 1/4 tank when it is dry.
longhorn71 is offline   Reply With Quote
Old 12-30-2004, 07:26 PM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Usually when the gauge is at the 3oclock position, it means it has a bad ground. My neighbor has the samp problem on his I think we tracked it down to the fuel tank selector switch for the dual tanks. Hope that helps...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 12-30-2004, 07:29 PM   #5
72 CustomCamper
huh ???
John
On the gauge it's self you shoould have 12v coming in from the pinkw/ black stripe wire. Then a signle going to the sending unit. The 3rd wire is the gauge ground...
Chuck
Old 12-30-2004, 07:47 PM   #6
784X4GUY
Did someone say MUD?
784X4GUY's Avatar
Yeap mine is real weird it sometimes reads right then sometimes it acts like it is sticking. Im trying to figure this out to so if anybody else has some info, I would appreciate it...Thanks Mike
Im in the market guys...so keep ya eyes peeled
Mini trucks are for guys who cant get it up!
784X4GUY is offline   Reply With Quote
Old 12-31-2004, 01:01 AM   #7
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
When measured like you said "90 Ohms from sender" the guage should read full. The GM senders in our trucks measure 90 Ohms when the tank is full, and 0 Ohms when empty. You are on the right track, reinstall the guage and remove the wire from the sender and ground it to the frame with the ignition on and check to see that the guage reads empty. You then know that the guage is OK. Because of the realitively low resistance used in our trucks, any corrosion or loose/dirty grounds will cause the guages to read inaccurately. Thus the "3 o'clock" reading usually indicates a bad ground on the fuel tank/sender unit causing high resistance.
The guage itself has a +12v lead, a ground, and the wire to the sender. Also check to make sure that the sheetmetal "nuts" on the back of the guage are makeing good contact with the resistor block (white porcelin) on the back as the guage uses this resistor for calibration.
It is also possible the sender itself is dirty/faulty and causing the reading to jump around. But check the connections first.
NeCrOmAnCeR is offline   Reply With Quote
Old 12-31-2004, 02:51 AM   #8
Stingray42
Woot.
Stingray42's Avatar
Chuck
i think this may get kinda confusing with three of us with problems... but here goes!
i had duals tanks and one was removed by the PO. now the guage did work, but with the needle at the wrong spots (half was empty, etc) then it stopped working, then i cut out the selector valve underneath the truck, now it still doesnt work. can someone give the volt reading that the guages should be putting out at full, empty, etc? also, where should you pick up power to check grounds, etc? ( i think this will help all three of us track down soem problems) Thanks!
Clarkson
Old 12-31-2004, 02:58 AM   #9
Russell
Professional Grade
Russell's Avatar
I heard somewhere that the little ceramic plate on the back can get corroded or whatever and cause the gauge to display inaccurately. Maybe pull it off, clean it up / shoot it with some contact cleaner?
Here is a picture of what I am talking about, the white peice with the blue center:
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-31-2004, 11:57 AM   #10
784X4GUY
784X4GUY's Avatar
I've also heard that tank selector valve can cause all kinds of problems. I have a fuel flow problem and Im thinking its because the selector valve is stuck in the middle. Im gonna have to replace that someday...Later Mike
Old 12-31-2004, 02:06 PM   #11
locab36
locab36's Avatar
I believe I've found the culprit. I went to local junk yard for another guage. They didn't have the exact one I needed (70's model ). I installed the older guage and it seems to work. I just didn't have the hole for the brake light. After looking at the guage I removed I decided to replace that little resisitor on the back and give it a try. That seems to have done it. Guage reads overfull ( 94 Ohms ) but I believe its accurate. When I was checking to see if it was the guage or sender I checked voltage back through the pink to the sender and was reading 3.4 v. Thats when I knew it was bleeding voltage back through the guage. Hopefully its fixed.
Thanks for the help.
John
Locab36
1956 BMW R25/3
1968 Moto Guzzi V7
1969 BMW R100/2
1986 Silverado SWB
2007 Harley FLHTP
Old 01-02-2005, 02:23 PM   #12
Stingray42
Woot.
Stingray42's Avatar
ok.... so if a have a bad ground, how would i go about fixing it? (3 o'clock position) does it require something in the dash or under the truck?
thanks again
Clarkson
Old 01-11-2005, 01:39 PM   #13
Stingray42
Woot.
Stingray42's Avatar
ttt....thanks
Clarkson
Old 01-11-2005, 11:02 PM   #14
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
response to stingray
quoted from necromancer:
... Because of the relatively low resistance used in our trucks, any corrosion or loose/dirty grounds will cause the gauges to read inaccurately. Thus the "3 o'clock" reading usually indicates a bad ground on the fuel tank/sender unit causing high resistance.
The gauge itself has a +12v lead, a ground, and the wire to the sender. Also check to make sure that the sheetmetal "nuts" on the back of the guage are making good contact with the resistor block (white porcelin) on the back as the guage uses this resistor for calibration. (end quote)
This is a great post. I've always had trouble with my fuel gauge. Although nothing that a good thump with the middle finger wouldn't fix. Figured mine was either the gauge or the dash connection. As long as I have at least one of my middle fingers, I'm not really worried about it.
Good luck & let us know how you make out.
-Todd
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 01-11-2005, 11:54 PM   #15
magnethead
7000 #'s of american IRON
magnethead's Avatar
our dually will read 1/8 tank when empty...but as long as we know that, i say who cares.
magnethead is offline   Reply With Quote
Old 01-15-2005, 01:19 PM   #16
76bonanza
76bonanza's Avatar
Hey chuck on that friend of yours truck did you just replace the switch in the cab? And how did you get it out. Mine is doing the 3 oclock thing and I think it is the switch because If I flip it back and forth a few times it corrects it self.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Thread Tools
Display Modes
