Old 01-02-2005, 03:58 PM   #1
70Yeller
1 ton coversion
Can a 1 ton dually 2wd be converted to a 4wd? Will it mount on a 4wd suburban frame? What is the easiest way if it is possible?
70Yeller is offline   Reply With Quote
Old 01-02-2005, 04:35 PM   #2
Rod
Kinda asking the same question in this post a week back.
http://207.44.196.117/vboard/showthread.php3?t=133547
suburban chassis is 127 inch while the dually 1 ton is either 133 or 157 inch.
Seems easiest way is if you want the dually and it's suspension..then put the engine 4x4 cross member in the frame and use the subs spring purchases and springs to mount what ever type front diff you come up with ...that being a dana 44 or dana 60. Both can be convereted to run dually front wheels, via spacer or get a dually front 60 to start with.
If you wanted a short wheel base dually you could use the sub frame and put a truck cab on it and convert the rear to dually. You have to use a trucks front cab mount on the sub frame..there different. Watch the height of the cab mount as you mount it also. A 4x4 mount is about 3/4 inch below the top of the frame rail....while a 2wd 1/2 ton sits flush to he top of the frame rail.
More info if needed, let me know,
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Thread Tools
Display Modes
