Old 01-02-2005, 10:02 PM   #1
slammd72
slammd72's Avatar
With Jb1, Jb3 Brake System Or Without!?
i was looking for brake parts for my half ton conversion and this question came up. what is the difference and what would be best since i have the oppertunity to choose?
88 shortbed crewcab
currently getting a sfbd 4 1/4"
slammd72 is offline   Reply With Quote
Old 01-06-2005, 10:31 PM   #2
slammd72
slammd72's Avatar
ttt
88 shortbed crewcab
Old 01-07-2005, 10:33 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Ok, I'll bite. What are Jb1, Jb3? Are you referring to standard brakes and HD brakes? Is that the option codes for 1" and 1.25" brakes. Help me out here....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-07-2005, 10:54 AM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
http://www.73-87.com/chevy_ids/rpo-hk.htm#rpo-j
That might help some...
I believe it differentiates between heavy duty or not, and power brakes or not. I also have been told that regular and heavy duty brakes take different spindles, so that may help you decide if you already have spindles on hand.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-07-2005, 12:05 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
That's what I thought, but was too lazy to look it up. Yes, the HD brakes requires different spindles, and calipers.
slammd72 if you are buying everything new any way, I would consider using the HD spindles, and buy larger calipers and rotors from SSBC, Wilwood or Baer. I would do a disc brake conversion on the rear while I was at it....
Articles-
"Refining Sierra"
Old 01-07-2005, 02:39 PM   #6
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
Not to be confusing, but my truck lists the heavy duty power brakes as J55 on my build sheet...
I agree, if you are going for new stuff anyway, get the HD 1.25" thick rotors (instead of the 1" thick) and the compatible spindles.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 01-07-2005, 04:58 PM   #7
Slonaker
Slonaker's Avatar
J55 76 88 BRAKE SYSTEM,H.D. PWR(VAR 1)
This is according to the link I posted.
Slonaker
Stock '01 Silverado
Old 01-07-2005, 10:51 PM   #8
slammd72
slammd72's Avatar
well i guess from some stroke of accidental genius i have bought the HD set up. i got the 3" dropped spindles (for the 1.25" rotor because bigger is better!!) by DJM from Summit. they got here a couple of days ago. i just got back from pep boys with the rotors, wheel bearings and the spindle nut kit. but heres what was weird. they had both of the rotors, (1" & 1.25" thick) so i just had the guy pull them both out and measured. easy enough...right? no way. then the wheel bearings. the wheel bearings that ended up working were for a 88 C2500 . but at least i have them now so that i can concentrate on all the other stuff. i.e complete upper and lower control arms, new ball joints, new bushings, calipers, dust sheilds?, rotor dust caps, shocks, and the caliper and dust shield mounting hardwear! but at least when this part is done ill have all 1/2 ton front suspension, be bagged, and refreshed suspension . ill post some pictures as soon as i start tearin in to it. thanx for the info.
my truck is an 88 OBS
JB3 76-88 BRAKE SYSTEM,VAC PWR DISC/DRUM
JB5 76-88 BRAKE SYSTEM,VAC PWR DISC/DRUM
88 shortbed crewcab
Thread Tools
Display Modes
