Old 01-06-2005, 10:56 AM   #1
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Will the defroster vents interchange?
The reason I ask is the right vent defrosts the glass about the the middle in front of the passenger,and the left one defrosts the bottom of windshield,and towards the middle of the glass,over the speaker,and the area in front of me is the last to clear.
Is it possible that it has 2 right hand vents?WIll they both fit in either place?It seems it would be blowing the right place if I turn it around,but the direction the hose fits on the bottom is angled the right direction.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 01-06-2005, 11:01 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The left and right vents are different. One has a round hose fitting and the other is an oval.
It's been awhile since I put any in, but there is a notch that needs to line up with the dash if I remember correctly. You'd have to remove the notch.
Old 01-07-2005, 12:50 AM   #3
72402
defroster vents
If you put the passenger side on the driver side, you can't hook up the hose. It gets into the instrument panel. Already tried it. Mine work about the same as you're describing. Frank
72402 is offline   Reply With Quote
Thread Tools
Display Modes
