Old 01-11-2005, 10:28 AM   #1
Hawged-67
ignition switch
Im parting out a '67 c/30 and a '68 k/20 chevys, I need to know how to get the ignition swithes out, they are 2 different styles.
'67 chevy on '79 K10 frame
Metallic Grey-Fleet White top
35in Ground Hawgs
355 ci, SM 465, NP 205
"A Dying Breed...Classic Chevy"
Hawged-67 is offline   Reply With Quote
Old 01-11-2005, 10:37 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Insert key, put pressure counter clockwise, insert pin in little hole while continuing to rotate the key counter clock wise and it should move, pull pin out and cylinder pops out on key.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-11-2005, 10:37 AM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
Process should be same for both styles as follows:
there is a little hole on the front of the switch, put the key in and turn it to the right to the acc. position. next push something small and hard into the hole you will fell it depress then turn the switch counterclock-wise until it stops, you may have to do this several times until it is freely moving. Then using the key remove the switch through the front of bezel.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Thread Tools
Display Modes
