Old 01-30-2005, 10:56 PM   #1
ACES
Life is a gamble
ACES's Avatar
Door Handle
My Passenger side door handle button (outside Handle) became Stuck today. The button is stuck inside the door. It won't return to the normal spot.
Anyone else have this problem?
Is it a spring that is broken or what?
Any ideas on how to go about fixing this?
-Art
1970 Orange CST C-10 w/350, posi, Longbed
The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine.
-- Ralph Waldo Emerson
ACES is offline   Reply With Quote
Old 01-30-2005, 11:02 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you mess with it enough, it'll probably pop back out. It is most likely about to break off. They used junk metal on the door handles. The button will probably end up falling into the door.
Old 01-30-2005, 11:02 PM   #3
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i think thats a kinda common problem once the handles get old. i dont know how to fix it though cause it has never happened to me
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 01-30-2005, 11:08 PM   #4
blazer1971
First try some W/D if that dosen't work you will have to remove the handle. After that look a back side and bend back tabs or push in the button area to see what is wrong with it.
blazer1971 is offline   Reply With Quote
Old 01-30-2005, 11:09 PM   #5
ACES
Life is a gamble
ACES's Avatar
So should I just buy a new handle and replace the whole thing?
Old 01-30-2005, 11:09 PM   #6
Longhorn Man
I don't think there is a fix...just replace it.
I've had it happen on 3 different doors.
i looked in wrecking yards and located one left and one right door handle and the chrome is almost prefect. (And this is up here in the rust belt)
Old 01-30-2005, 11:10 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
MIGHT AS WELL, IT WON'T TAKE LONG TILL IT BREAKS FOR GOOD
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-30-2005, 11:11 PM   #8
ACES
Life is a gamble
ACES's Avatar
OK,
I'll price some door handles tomorrow
THanks everyone
Old 01-31-2005, 01:25 AM   #9
GMCPaul
Thumbs up
When GM made the exterior door handles they installed a spring behind the button and put a plate behind the spring to keep tension on it, however to retain the spring plate they put 4 tabs on the handle and only folded 2 of these 4 tabs over, so as soon as 1 tab breaks this allows the spring plate to cock at a angle causing buton to become stuck inside handle or plate falls completly off allowing button to fall inside the door, occasionly you can get away with removing the handle and putting spring & plate back on then heating the unbent tabs some you can slowly bend them over to hold plate in place. This fix when it works without tabs breaking when you try to bend them generally gets you another year or 2 of use out of the handle.
We carry new reproductions of the exterior door handles triple chrome plated with all 4 spring plate tabs folded over instead of just 2 of them and they come with mounting hardware & gaskets.
You'll find we have pairs available on our sale page here
http://www.gmcpauls.com/SALE_SPECIALS.htm
If your looking for just 1 handle you'll find it here on our web site
http://www.gmcpauls.com/door_parts2.htm
There are multiple outfits reproducing these so all exterior handles from all suppliers are not the same, 1 place folds 2 tabs just like GM did, another place does folds all 4 tabs but most the time the pot metal tabs on the new handles are already cracked and just waiting to break, where as ours have all 4 folded over and are not cracked when bent over.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 01-31-2005, 02:32 AM   #10
69 Short Fleet
GMC Paul, good info!
69 Short Fleet is offline   Reply With Quote
Thread Tools
Display Modes
