Old 01-31-2005, 10:56 PM   #1
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Timing Problems
I recently swapped the motor into my 70 4x4 and have had a problem trying to get the engine running right. I replaced the distributor and made sure that it was on #1 TDC, the engine will start and run perfectly no miss or sputter except when I hit the gas then hesitation and backfire, when it's in gear and under a load it bogs down when the gas is applied. I have twisted the dist. every which way, if I go counter clockwise it doesn't seem to backfire as bad but when it is shut off it will not start unless it is turned back clockwise. Could a bad spark advance cause this, where it runs fine at idle and acts like that when at higher rpms? Could one work partially, at lower rpms and not higher?
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 01-31-2005, 11:35 PM   #2
mr402
Check the centrifugal advance. Just pull the cap off and make certain it moves freely.
mr402 is offline   Reply With Quote
Old 02-01-2005, 11:48 PM   #3
Firefighter
Thanks, I spoke to a mechanic friend of mine today and that is what he said also. Hopefully I can get home early enough tomorrow to check it. Thanks for the reply!!
Yellville, Ar. USA
Old 02-02-2005, 12:21 AM   #4
jhow66
jhow66's Avatar
You need to reset your dist. -sounds like it is off a tooth or two.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Thread Tools
Display Modes
