HELP - Backfire/Popping thru Exhaust !!!!!
Finally got the 454 off the test stand and dropped in the 72, and now the problems start. When the motor was on the test stand (about a month ago) everything seemed to run fine (ran it for about 1/2 hour or so). After I dropped it in and got everything hooked up the motor fired right up and sounded fine, ideled good, great throttle response and so on but.........once I take the motor to about 2500 rpm it begins to backfire/pop thru the exhaust.
Thought it was timing - re-dropped distributor in twice, adjusted the timing everywhere on the scale Thought it was tight valves - readjusted all the vavles NOTHING HELPED... do not know where to go from here....... The only thing different from when the motor was on the test stand is the MSD Box (6AL)??? Could that be bad it is only 6 months old and ran fine when I pulled it off the sbc. The motor is a used motor that I bought a while ago that is why we put it on the stand and fired it so we wouldn't have these issues Any suggestion are greatly appriciated thanks guys
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years ![]() |
Run it without the box and see.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Beer Power!!!!!!!!!!
It does sound like timing. I would check to see if the timing chain is loose. But only after you have exhausted everything else first.
Rather be fishin' |
jhow - Hopefully tonight I can take the box off and see
Perchjerker - Timing was also my first guess, maybe the box off will help, maybe bad box ??? No one else can come up with something ![]() thanks guys
Glowing since 1978
It sounds like a timing issue to me also. Do you have a dial back timing light to check what timing you have at that RPM or a degreed balancer/damper? Timing is usually all in for mechanical and maybe your total timing is to much. Don't know what the distributor setup is. I would also take the box out of the equation and see what the results are. Electronics are great when they work and a big headache when you have problems. Also check 5 and 7 plug wires carefully. They are right next to each other in location and firing order. You might be getting a little cross fire going on.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
![]() Join Date: Sep 2001
Sounds like your timing is too advanced. A motor will idle just fine with the timing too advanced sometimes. WOT will bring the engine to it's knees. Not enough fuel/air charge in the combustion chamber at the right time. The motor is already throwing it out the exhaust stroke.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
also check your plug wires just to make sure they are all going to the proper plug. I thought I had mine on right and it would idle perfect but once it got to about 2400 rpm she would start chuggin and backfiring. I went by my Haynes manual for the plug wires and then looked at my intake and they were different. SO I lined em up as it said to on the intake and problem solved. Check the little things first bud and let us know what turns up
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
What type of distributor are you running?? If it's an HEI maybe it is the ignition module. I have never had this problem, but I know when they test them they test low and high rpm not sure where the line is between low and high rpm though. Just an idea and it is free to get them tested at your closest Advance auto parts or whatever.
71 Chevy Long Bed (gettin' bagged) 84 GMC K1500 (Sold) 85 Monte Carlo SS white w/gray int. (being a dumba** and totaled it ![]() 85 Monte Carlo SS clone T-top (Sold) 72 Chevelle-tubbed 64 Buick Sportwagon |
Do not have a dial back timing light just the old school one - although that might be a good investment
![]() It is a 50,000 volt HEI Thanks guys, I am trying to leave work here in the next couple minutes and head that way. I will go over her one more time tonight with the following: 1.Check plug wires - both on the cap and at the cylinders 2. Make sure wires aren't crossfiring 3. take MSD off 4. Check module tomorrow at parts store if still not right AGHAHAHG the good ole days Thanks guys
Member since 2000
Check your spark plugs.............i had one plug loose and the whole time I thought it was a timing issue...............
I had a bent valve in a motor once and it did the exact same thing....
Big Block update - Well last night went thru everthing we could think of
New cap and wire Valves so loose they all rattled Spark plugs Timing advanced, retarted then advanced Nothing helped, it was still popping and backfiring soooooo....as of now she sits stripped down to the short block. Heads on the floor going in for valve job, 292 cam off the shelf to slap in, then MAYBE when we get it back together the pop will be gone. WE HOPE???? ![]()
Thread Tools | |
Display Modes | |
