I hauled a load of firewood, after unloading I put the longhorn in drive, and there was none. I had reverse, but no forward gears. What a bummer. I replaced filter, and checked modulator rod for movement. It seemed to be moving. So I pulled out the tranny, waiting to carry it to a buddy for a rebuild. I wish I had some warning.
Fayette Alabama |
What a pain in the A$$ soooo sorry to hear that I went through two powerglides (BUILT) and two th350s in my 75 swb, no wood just a 327 and 3500 stall. hope to have better luck with my 70
70 swb restored by myself and some help from this board!! I hope to drive it some day!! portland OR |
![]() Join Date: Sep 2001
First thing I would do before pulling the pump is check for a stuck valve body. Doesn't sound like the catastrophic failure that would warrant a rebuild. Sounds like a valve is stuck preventing the servos from engaging the primary clutches. Just a thought...
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
I'LL TAKE THAT ADVICE
Thanks NEWOWNER69, I'll talk to my buddy about that. Too bad I already pulled the tranny out:
Fayette Alabama |
As long as you have it out, I would rebuilt it just to have piece of mind. It isnt that expensive to overhaul a Turbo 400.
Thread Tools | |
Display Modes | |
