Old 02-14-2005, 10:10 AM   #1
bestchevyfan
Cab???????????
How Do You Tell A 67 Big Window Cab From A 69-72 Cab? Was It Only In 67 That Had A Small Window. Thanks,buddy
bestchevyfan is offline   Reply With Quote
Old 02-14-2005, 10:22 AM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
67 had the only small back window, as to tell the vin plate. there are other little things, like the side vent handles are different on 67-68, location of mirrir 67-70, and other little things i dont know
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 02-14-2005, 10:48 AM   #3
72MARIO
72MARIO's Avatar
The firewall has holes for the foot E brake and Cable operated gas pedal on the 69-72 ? The copperhead Cab was actually a 72 Style he called it a 67 But I know it isnt'
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-14-2005, 12:24 PM   #4
John Fabris
TOTY 2006
John Fabris's Avatar
The dash is different. More specifically, the ignition hole, and lighter hole, are not the same. Don't have pictures to compare, but I you need that, let me know.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 02-14-2005, 12:24 PM   #5
CHEVYE
my gas saver
CHEVYE's Avatar
the glove box door in a 67 (if it`s og.) will have a crinkled black finish on it too.
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
Old 02-14-2005, 04:11 PM   #6
bestchevyfan
Cab?????????????????????
ttt
Old 02-14-2005, 09:17 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The 67/68 will have a hand brake for the parkign brake, also the fuse box is mounted 45 degrees off from the later rigs, the aformentioned things too.
Old 02-14-2005, 09:50 PM   #8
70short/step
70short/step's Avatar
I didnt think the 69-70 had Cable gas pedal. Mine doesnt. Was it an option?
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 02-14-2005, 09:56 PM   #9
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
nope 71 was first year for cable, prior to that was a rod.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-14-2005, 09:57 PM   #10
No 69-70 were rods!
Since they have rods, they become hot rods without much effort
Thread Tools
Display Modes
