Old 02-18-2005, 06:46 PM   #1
sakohntr
sakohntr's Avatar
how big a tire can i ....
How big a tire can i run with 8 inches of lift in this vintage of truck?? thanks
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 02-18-2005, 06:56 PM   #2
drink2mny
drink2mny's Avatar
i've seen 38's on nice trucks, and i've seen 39's on beat up fenders trucks..
I guess depends what you plane to do with it..
daily driving i would go with 38's. probably 38x 12.50's
Support The Board
drink2mny is offline   Reply With Quote
Old 02-18-2005, 07:19 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
pont has wide 35s.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-18-2005, 07:39 PM   #4
redz 1970 K5
OBS guy
redz 1970 K5's Avatar
Perfect tire for 8" lift- 37x12.50 Goodyear MT/R! I love those tires... You can do a wide 35-36 on a 12-14" wide wheel or a more narrow 37 or 38 on a 10" wide wheel. Depends on how you want it to look and how functional you want it to be.
88 Suburban
Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear,
Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more
redz 1970 K5 is offline   Reply With Quote
Old 02-18-2005, 07:56 PM   #5
ryanroo
ryanroo's Avatar
i have a 39-15/16.5 on my 72 K20 with an 8 inch all spring lift. not on the road right now but i never had it rub when it was, and i flexed it out a few times. the 8 inch spings are pretty stiff so alot of the flex is frame flex. ill see if i can scrape a picture up later
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 02-18-2005, 07:59 PM   #6
ryanroo
ryanroo's Avatar
there it is, it has no engine in these pics, but i had a 454 setting in it before with little change in clearance. had a 350 deisel in it to and no problems there. FYI i am looking to sell the tires
Ryan
72 K20 12v build
Old 02-19-2005, 02:35 AM   #7
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I would say some 38" x 14.50" or 15" maybe if you got the right rim set-up, probably 39" but you probably would have some fender problems. Depends on how much of a daily driver or street driven truck you want.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 02-19-2005, 09:04 AM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I have 35 x 12.5 x 15's on a 4/6 lift, no issues at all, I'd say up to 39" high
would be ok, width is where you need 2 be careful, especially w/ wide rims
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-20-2005, 11:32 AM   #9
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Ponts wheels are really wide and do rub on the front fender cups.. With a narroe wheel the would not rub.. Luv it sure looks like those bfgs are gonna rub in the front on full lock turns into driveway's..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-20-2005, 11:35 AM   #10
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
NOPE, BEEN ROAD TESTED SEVERAL TIMES
Old 02-20-2005, 01:45 PM   #11
oakleyspeed
hey i just installed 8" springs on my 72 K20 and put 355/70R17 toyos on 10" wide wheels and they fit perfectly no rub at all (tire size= 37/14 approx) i think it fills up the wheel wells just right hope this helps.
oakleyspeed is offline   Reply With Quote
Old 02-20-2005, 01:51 PM   #12
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
OAKLEYSPEED, SOUNDS COOL, 2 THE BOARD FROM W. 10-UH-C
Old 02-20-2005, 03:33 PM   #13
GMC71k20
ponts wheels rub because of his backspacing i think. alexis has fit 40s with 8" lift.
ryanroo- are yout hinking about selling those tires again - i may be thinking about buying them again...pm me with more details and where you are
GMC71k20 is offline   Reply With Quote
Old 02-20-2005, 06:33 PM   #14
ryanroo
ryanroo's Avatar
You've got mail! thanks
ryan
72 K20 12v build
Old 02-20-2005, 10:34 PM   #15
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Here is 9 inches on true 38's x 15.50. They do rub on medium level flexing. Run 8 inches at your own risk.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 02-22-2005, 11:08 PM   #16
ricochet442
have any of you guys with 8 inches of suspension lift had any trouble with front driveshaft angles or having to use specialty drive shafts,also how about steering with this much lift? is crossover a must? thanks in advance for the help.
1972 chevy 3/4 ton 4x4
ricochet442 is offline   Reply With Quote
Old 02-22-2005, 11:29 PM   #17
ryanroo
ryanroo's Avatar
I have a steering block and a drop drag link on mine, and the steering is ****ty. uncentered and some noticable bumpsteer. i strongly recommend crossover. i had no problems with driveline angle, and i am running a dana 60 which has a 2" longer pinion. no specialty drivelines needed, just went to the driveshaft shop and told them the length.
Ryan
72 K20 12v build
Old 02-23-2005, 03:02 AM   #18
Liftedassdodge
The Stunt Guy
now thats a clean rig
Liftedassdodge is offline   Reply With Quote
Thread Tools
Display Modes
