Old 02-19-2005, 12:00 AM   #1
jetfixr
Edelbrock Carb adjustment
OK, finally got my crate motor in. Now I am in the process of getting my TV cable set for my 700r4. I am re-using my edelbrock 1406 from the old motor. It is running rich as hell but I have no idea how to adjust it (lost the manual). The idle adjustment for the linkage is pretty obvious, the only other 2 adjustment screws I see are the 2 big screws in directly in front of the forward barrels. I have no idea what each of them do, or how they should be adjusted. Can someone give me the quick-and-dirty on this?
jetfixr is offline   Reply With Quote
Old 02-19-2005, 12:07 AM   #2
thisolechevy
o.k. here is how to adjust your 1406 (or 1405 manual choke) set your RPM at 850-1000 then back off the two front screws starting on the right until the engine idles the highest on each screw. After your motor is idleing at the highest RPm the screws allow TIGHTEN each screw 1&1/4 turns. Then set the engine idle RPM where you like (usually 650-800) mines at 700. It should run alot smoother for you, but if this doesnt work right let me know and I will give you further instructions.
brad
Man I need another 67-72!!!
thisolechevy is offline   Reply With Quote
Old 02-19-2005, 03:11 AM   #3
QKENUF4U
QKENUF4U's Avatar
hmmm thats bass akwards to what ive always been told to do with these type carbs. i have always turned them IN till the motor starts to stumble then back them out a turn or so
QKENUF4U is offline   Reply With Quote
Old 02-19-2005, 10:34 AM   #4
thisolechevy
hmmmm I have always taken them out let me check my edelbrock manual....ok the manual says to adjust each screw until reaching the highest rpm...so I guess either way tighten or loosen will work. I have always had to loosen
Old 02-19-2005, 11:33 AM   #5
GMan69
GMan69's Avatar
I may be totally wrong, but I believe the screws on the front adjust idle mixture only. If you want to change the mixture for cruise or power, you will need to change primary metering rods and/or primary and/or secondary jets. This is easy to do on Edelbrock carbs and can be accomplished without removing carb from intake. Go to edelbrock.com and find their instructions for tuning/ calibrating the Performer series carburetor. Hope this helps.
George Morgan
Hernando, MS
'69 C-10 swb fleetside
'72 GMC swb Stepside
GMan69 is offline   Reply With Quote
Old 02-19-2005, 11:44 AM   #6
danho
Pesemistic Optimist
danho's Avatar
Here.
http://www.edelbrock.com/automotive/index.html
1972 K20 Cheyenne Super Custom Camper- 4" lift & 35's, built TH350 and 355. Daily driver resto in progress.
1999 Yukon Denali- Wife's ride, hands off.
danho is offline   Reply With Quote
Old 02-19-2005, 12:06 PM   #7
ezernut9mm
ezernut9mm's Avatar
man, this place rocks! another question answerd and i didin't even have to ask it.
'06 silverado (daily driver)
'02 nissan sentra (wal-mart warrior)
ezernut9mm is offline   Reply With Quote
Old 02-19-2005, 12:47 PM   #8
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
This is correct. The trouble is finding the right rod/jet combo. I just bought a Strip Kit with bunches of rods, jets and secondary vacuum springs. If its running too rich, you need to reduce the orifice size of the jet. You may have to change the jet, rod or both to do this. And OMG be careful removing and reinstalling the bowl cover screws. Don't ask, I'm trying to block out those memories.
'69 Chevy 3/4 ton, 327cid, Carter AFB, Edelbrock intake, HEI, TH400.
Founding member of the No Money To Spend On My Truck Club.
When your at Home Depot, you WISH you had gotten an 8 foot bed!
Cat Fuzz is offline   Reply With Quote
Old 02-19-2005, 01:35 PM   #9
dave3156
I just bought a new 1406 with automatic choke. The literature says the carb comes factory adjusted and should need no further adjusting. Seems like the idle is too high to me. When I first start it and its in high idle before I release it by kicking it down, its so high it about wakes up the neighbors! Even after kick down it still seems too high. At idle it seems like its racing a bit. Has anybody bought one of these and not had to adjust anything, or is the literature making it sound too easy?
dave3156 is offline   Reply With Quote
Old 02-19-2005, 01:43 PM   #10
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i did that with my straight 6 carb, all the sudden, damn where is that screw? the good thing was i could still see it down in the carb, nothin a magnet couldnt fix
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 02-19-2005, 08:30 PM   #11
RON WOODGEARD
Resident Young Old Dude !
The literature is making it sound too easy!!! You're going to have to do some adjusting on 8 out of ten motors..
The two screws on the front of the Carb. are idle circuit adjustments only.
Anyone who has one of these carbs should have the "STRIP KIT" it's essential for tuning...
I didn't go to the link Provided, But Catfuzz has it right.. If it isn't too far out of whack, You can get by with just removing the 2 small plates on top of the carb and changing the metering rods, but you MAY have to change the jets to a smaller size, if it's too rich.
If you have a "AIR FUEL RATIO GAUGE" that's where the different sized springs will really come into play in tuning throughout the RPM range under power in actual driving conditions. Or a dyno if you're fortunate enough to access to one..They will control when the rods raise and allow more fuel to run through the jets. and you can tune them "By the seat of the Pants."
RON WOODGEARD is offline   Reply With Quote
Thread Tools
Display Modes
